I think there is no use to go oem route in such a tiny aspect. As they are NLA for a long time. Just make the poly bushes black and all good. Friend of mine got them almost 1:1 from exterior as oem.
I assumed they would be NLA, just thought maybe someone had a source for quality replacements...…… looking like poly it is then!
The rear diff mount uses a nearly identical insert to the one used in MK1 Golf gearbox mounts, I'd go for one of those of over poly which I found increased how much I noticed the drive train lash.. However the main sub frame bushes in medium density poly are great, simple to fit unlike the stock ones and aren't at all harsh. I had black Superflex ones fitted to my S2 front and back and couldn't have been more happy with them, they were the final thing I changed in an effort to get nice tight handling on main roads with a bit of give to soak up bumps etc. They replaced the solid alloy ones fitted when I got the car which were awful.
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.
......I'd go for one of those of over poly which I found increased how much I noticed the drive train lash..
............the main sub frame bushes in medium density poly are great, simple to fit unlike the stock ones and aren't at all harsh. I had black Superflex ones fitted to my S2 front and back and couldn't have been more happy with them, they were the final thing I changed in an effort to get nice tight handling on main roads with a bit of give to soak up bumps etc.
Thanks Kit, always good to hear of someone's experiences.
I had heard the poly diff mount transmits a lot of drivetrain harshness...……..that VW one will do nicely, maybe fill the air gaps with Sikaflex though!
Regards the subframe bushes, I'll go with the black Superflex ones then, I've got poly's on the front but can't remember if they're Superflex/Powerflex/whatever?
Thanks for taking the time.
