Rear brake upgrade
  • Dobby84
    • Feb 2011
    • 1169
    Rear brake upgrade
    Anyone got a rear brake upgrade they may be selling?
    Have you looked at the kit rusty did for the brake carrier to fit larger discs?
    • Dobby84
      • Feb 2011
      • 1169
      I'll check that out
      • Monkeymagic
        • Mar 2012
        • 3419
        Is it a coupe or avant. I've just upgraded my coupe to 302 mm a6 rear discs using original calipers and epitec brackets..
        • Dobby84
          • Feb 2011
          • 1169
          Yeah it's a coupe. Who did you get the brackets from?
          • tango123
            • May 2017
            • 892
            • Dobby84
              • Feb 2011
              • 1169
              Cheers Mate, dont suppose you have a PN for the discs? Did you need different brake lines or cables?
              • tango123
                • May 2017
                • 892
                trw part no DF4776. let me know if you need some discs.I can supply them through work. Im not sure on fitment as i haven't done the conversion but i think it all works with factory calipers etc
                • Monkeymagic
                  • Mar 2012
                  • 3419
                  Audi A6 C5 302 rear discs. It says on epitec website part numbers. I used pagid ones. Brackets come with all hardware. Cables and hoses fit as if intended. a really simple easy mod.
                  only bit of fabrication is taking a bit of metal off caliper carrier with an angle grinder .. easy
                  • Dobby84
                    • Feb 2011
                    • 1169
                    Love a bolt on solution that needs 'a bit of fabrication' lol
                    Added it to my list to but on pay day
                    • tango123
                      • May 2017
                      • 892
                      recieved mine yesterday
                      • LukasR
                        • Nov 2014
                        • 166
                        By adding bigger disc you achieve next to nothing, Calipers are the weak point.
                        The most common upgrade is fit calipers from s6 c4 (Girling 41/43) using s2 carriers, you can use disc from s6 c5 269mm
                        • Monkeymagic
                          • Mar 2012
                          • 3419
                          This gallery has 1 photos.
                          • tango123
                            • May 2017
                            • 892
                            looks much better than the tiny stock disc
                            • Monkeymagic
                              • Mar 2012
                              • 3419
                              I need to clean and paint my calipers. May do my brake flexi lines too while I'm at.
