Rear brake upgrade
  • Dobby84
    • Feb 2011
    • 1169
    Rear brake upgrade
    Anyone got a rear brake upgrade they may be selling?
    Have you looked at the kit rusty did for the brake carrier to fit larger discs?
    • Dobby84
      • Feb 2011
      • 1169
      I'll check that out
      • Monkeymagic
        • Mar 2012
        • 3419
        Is it a coupe or avant. I've just upgraded my coupe to 302 mm a6 rear discs using original calipers and epitec brackets..
        • Dobby84
          • Feb 2011
          • 1169
          Yeah it's a coupe. Who did you get the brackets from?
          • tango123
            • May 2017
            • 892
            Bremssatteladapter um an der Hinterachse des Audi S2 Coupe (nicht passend bei Avant und Limo) und baugleichen Hinterachsen Audi A6 Bremsscheiben in 302x12mm zu montieren.Mit unseren Adaptern können die Original Audi S2 Coupe&nbsp…
            • Dobby84
              • Feb 2011
              • 1169
              Cheers Mate, dont suppose you have a PN for the discs? Did you need different brake lines or cables?
              • tango123
                • May 2017
                • 892
                trw part no DF4776. let me know if you need some discs.I can supply them through work. Im not sure on fitment as i haven't done the conversion but i think it all works with factory calipers etc
                • Monkeymagic
                  • Mar 2012
                  • 3419
                  Audi A6 C5 302 rear discs. It says on epitec website part numbers. I used pagid ones. Brackets come with all hardware. Cables and hoses fit as if intended. a really simple easy mod.
                  only bit of fabrication is taking a bit of metal off caliper carrier with an angle grinder .. easy
                  • Dobby84
                    • Feb 2011
                    • 1169
                    Love a bolt on solution that needs 'a bit of fabrication' lol
                    Added it to my list to but on pay day
                    • tango123
                      • May 2017
                      • 892
                      recieved mine yesterday
                      • LukasR
                        • Nov 2014
                        • 166
                        By adding bigger disc you achieve next to nothing, Calipers are the weak point.
                        The most common upgrade is fit calipers from s6 c4 (Girling 41/43) using s2 carriers, you can use disc from s6 c5 269mm
                        • Monkeymagic
                          • Mar 2012
                          • 3419
                          This gallery has 1 photos.
                          • tango123
                            • May 2017
                            • 892
                            looks much better than the tiny stock disc
                            • Monkeymagic
                              • Mar 2012
                              • 3419
                              I need to clean and paint my calipers. May do my brake flexi lines too while I'm at.
