hi there guys,time has come to change my rear pads & discs.What have most found as a good setup?
Rear brakes
Not for sale but iirc Newsh has a nice little rear setup that i think i will give a whirl...
EBC pads
Crossed & Drilled discs ??
I had EBC pads on my other audi and must say i was very impressed with the bite and they are still going strong 2 years on, HTH
ChefComment
you should be able to find most of the current setups and what people have tried via the search function, the setup that newsh and others have are based around GD605 (EBC part) and ebc red stuff pads, go and look at www.ebcbrakesdirect.com
around £135 for a new rear setup
HTHComment
OEM Pads OEM discs, If it ain't broke....
The Perfectionist
pagid fast road pads and drilled (GSF) 'forget the name' discs. Seen me fine for over 6 years (same set) They will crud up and need changing long before they actually wear out... The rears do so little work its not worth spending a massive amount on them IMO unless you are going to go for vented discs etc instead.sigpic
1992 3b S2 CoupeComment
I am converting my car to V8 quattro rear calipers and rotors. They cost me very little to get the full kit build. 20 USD for calipers 66USD for the rotors shipped, and 130 for 4 SS flex lines for the car with 996 front calipers. The vented brakes are the biggest bang for the buck IMO. I also have a set of S8 carriers for when the time comes I need 300mm Rears
I know my brothers US spec CQ has ebc yellow stuff pads on cross drilled rotors and it stops ok, but nothing like the vented conversion with slotted drilled fronts and decent pads. Just my $.02.Sean
91 CQ Elanor 1.9L compound Turbo build. Fully built internals, full race oval port head, custom race cam. GT2256v and hy35 in compounds.Comment
Zimmerman - £43.50+VAT ea. (GSF P/no 62396EF I think). Linky
I have Pagid TQs (£29.50+VAT) at the moment with Zimmerman discs. I was told that they did not do fast raod rears
. FRs are cheaper than the TQs!
No idea how they work as the 996s try and pull the back of the car off the ground on the standard springs!!!
Iain it was purely cosmetic behind the old original 5 spoke alloys. Agreed there is zero performance advantage but equally they have worn nicely so cant complain really
From memory the V8 rotors (discs) and calipers are same as RR engined UR (269x20) - which means the hat height is all wrong for carriers from an RR or UrS4/S6. Are you getting some custom carriers made for this rear conversion ? Or am I utterly wrong on my assumption about hat height ?I am converting my car to V8 quattro rear calipers and rotors. They cost me very little to get the full kit build. 20 USD for calipers 66USD for the rotors shipped, and 130 for 4 SS flex lines for the car with 996 front calipers. The vented brakes are the biggest bang for the buck IMO. I also have a set of S8 carriers for when the time comes I need 300mm Rears
PaulPaul Nugent
