Drive shaft rear for RS2/S2
  • joss01
    • Apr 2019
    • 384
    I am after a rear driveshaft and one front driveshaft for an RS2/S2 my cv joints are knocking. Alternatively are there any options avaiable as I cannot find any for sale
    • Dec 2017
    • 5991
    Just change the CV Joints Joss. Shafts will be fine
    • joss01
      • Apr 2019
      • 384
      hi dave are the cv joints the same on the back and front shafts?
        • Dec 2017
        • 5991
        No. Front outer are different to rear outer. I think the inners are the same front and rear but you need to double check. I did mine ages ago.
        • joss01
          • Apr 2019
          • 384
          do you have the part number for the outer back and front?
            • Dec 2017
            • 5991
            You will need to check on 7Zap as although my suspension is RS2 spec my driveshafts are S2 Avant and there might be a slight difference.
            • joss01
              • Apr 2019
              • 384
              S2 shafts are the same as RS2 just cant find rear outer cv
                • Dec 2017
                • 5991
                Might help you.
                  • Dec 2017
                  • 5991
                  Get them direct from SKF here Joss. There are so many fakes out there SKF set this up to combat this. I've used them and they are very quick.
                  Wherever you are based, our large network of distributors can provide the parts you need to keep moving.
                  I suggest you replace them all in one go
                  • joss01
                    • Apr 2019
                    • 384
                    many thanks dave
