ABY crank pulley/vibration damper
  • Farhazaftab786g
    • Nov 2017
    • 169
    My Avant keeps going through alternator belts 3 now and the only thing it looks like is the crank pulley as it wobbles quiet abit.
    Does anyone have one for sale ?
    Emerald Green ABY Coupé
    RS2+ Spec
    @audis2kid - instagram
    • Dec 2017
    • 5992
    I have a fluid damper.
    • Rikki Kitto
      • Feb 2010
      • 6276
      Without sounding like I'm being stupid as actually I was I had same issue and it was just me being a bit heavy handed tightening the belt, I use one of Alex's adjusters and it took a while to realise how easy it was to over tighten the belt
      • Farhazaftab786g
        • Nov 2017
        • 169
        I suppose so but each time it has shredded i have tried a different tension and still the same
        RS2+ Spec
        • K Simmonds
          • Dec 2007
          • 7627
          I can't help with an ABY/ADU one, I do have 3B/7A ones but they're no use to you, I know brand new ones are no longer available unless AT have found some in the back of a warehouse somewhere.
          I can recall a mate buying what Pete Reeve claimed to the last new one in existence back in 2016 and it was dam expensive!
          1990 B3 2.0 80 quattro.
          1992 C4 2.8 Avant quattro
          1994 MTM RS2.
          1998 B5 TDI quattro Sport.
          2000 B5 TQS.
          • Farhazaftab786g
            • Nov 2017
            • 169
            I do remember reading that you could swap the alternator pulley for a V belt one so then a 3B/7A crank pulley can be used.
            I want to keep it original though and retain an ABY.
            Finding a used one seems to be rare as hens teeth
            RS2+ Spec
            • K Simmonds
              • Dec 2007
              • 7627
              Yeah, you can do that and it'll work fine. That's what my RS2 will be getting should it ever need one as I have three good spares sat on the shelf and thankfully my current ADU one has only covered 100K miles and still run's as straight as it did new.
              If your really stuck feel free to drop me a PM as like I say I've got three, two of which are spare and I also will have the alternator pulley as well.
              1994 MTM RS2.
              2000 B5 TQS.
