RS2 rear wheel bearings
  • Rikki Kitto
    • Feb 2010
    • 6276
    Need a source and a part number if anyone can help, my S2 has RS2 hubs etc so finding parts can be tricky
    • Dec 2017
    • 5984
    82mm same as S2 Avant. Get them direct from SKF to avoid counterfeit ones.
    • Rikki Kitto
      • Feb 2010
      • 6276
      Cheers bud thought you might know this, only one has gone but gonna do both
      • Rikki Kitto
        • Feb 2010
        • 6276
        Do you know the part number I'm confused
          • Dec 2017
          • 5984
          7zap is dead so I don't know the part number. If you go on the SKF website you can search under your registration. I did a manual search entering 1995 RS2 to get the link above.
          • B5NUT
            • Sep 2021
            • 1071
            Part number of the rear wheel bearing and it's still available at a silly £136 from Audi
            • Rikki Kitto
              • Feb 2010
              • 6276
              Problem is I have a Coupe with RS2 hubs so Reg won't work
              • Rikki Kitto
                • Feb 2010
                • 6276
                Any RS2 owners let me use their Reg to find it
                • B5NUT
                  • Sep 2021
                  • 1071
                  Think this is the RS2 press car
                    • Dec 2017
                    • 5984
                    While we are talking about wheel bearings, Euro Car Parts have made a price error on 75mm rear coupe bearings and they are £3.69 each for the Q drive brand. Not a great brand but worth getting a couple as spares. The also fit the TQS rear.
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      Is this what I need? I thought front and rear had differences I need rears
                        • Dec 2017
                        • 5984
                        Ok. Confusion here.
                        You have RS2 hubs. Hub carriers must be coupe as carriers on RS2 are completely different and would not work on a coupe. So what you need is 75mm outer and inner to match the RS2 hub spindle. Am I correct? If that is the case I think you will need to pull one and check the part number. I think it will be same as rear B5 Quattro as it has 75mm outer and inner same as S2 Avant but you best check.
                        s2 Avant has 82mm front and rear. Coupe has 82mm front and 75 rear.
                        • pfi
                          • Jun 2016
                          • 274
                          • Country: Norway
                          Rear Coupe with RS2 hubs, how did You do that ?
                          Coupe has 75mm bearings, RS2 has 82mm ...
                          pics ?
                          • Rikki Kitto
                            • Feb 2010
                            • 6276
                            Hi the car had an RS2 conversion when I bought it apart from the engine which I've done since I've had it
                            • Rikki Kitto
                              • Feb 2010
                              • 6276
                              Must a mix of coupe and RS2 bits as my wheels have the 5×130 porsche spacing, remember the front bearings are strange with different diameters half way in or am I going mad
