RS2 rear wheel bearings
    • Dec 2017
    • 5992
    I've been searching the forum but can't find the RS2 rear hub dimensions. Apparently the rear hubs are longer to accommodate the handbrake mechanism. I think you will need to pull one and get a part number or dimensions. Front should be identical to S2.
    • pfi
      • Jun 2016
      • 274
      • Country: Norway
      Both front and rear bearings have two different inner dia's, that's normal.
      Front conversion to RS2/5x130 should be no prob, std 82mm bearings AFAIK
      but,
      If You have a Coupe I don't understand how RS2 is fitted, all Coupe's has 75mm hub-carriers/bearings and the S2/RS2 (sedan/avant) has 82mm ...
      The rear ACOQ and RS2 is totally different
      ACOQ is B3
      RS2 is B4/B5
      • Rikki Kitto
        • Feb 2010
        • 6276
        Could I have S2 coupe carriers on the rear with RS2 hubs for the 5×130 stud spacing
        • pfi
          • Jun 2016
          • 274
          • Country: Norway
          RS2 hub spindle will NOT fit std ACOQ carrier as RS2 is for 82mm bearing and ACOQ carrier is for 75mm bearing ...
          If You got setup as described someone must have done some serious mod's
          Take some pic's
            • Dec 2017
            • 5992
            You will have to pull one and see what you've got
            • pfi
              • Jun 2016
              • 274
              • Country: Norway
              #21
              B4 / B5 rear :
              B3 (ACOQ) rear :
              • B5NUT
                • Sep 2021
                • 1071
                I wondered that, (not about going mad) I'm talking about the rear RS2 setup as they are miles apart from the coupe
                The RS2 bearing does not look like it would fit the coupe running gear as it 82mm on the RS2 v the 75mm on the S2 coupe
                S2 coupe bearing
                Are your sure you don't have a standard S2 setup on the rear, as I don't see the point of trying to somehow get the RS2 hub to fit the S2 wheel bearing housing. Or am I talking nonsense and have missed the point completely.
                  • Dec 2017
                  • 5992
                  It will just be the hub that's been changed to accommodate Porsche wheels. The hub carrier will be standard and 75mm wheel bearing od size. We just need to establish what the inner diameter is and what bearings fit.
                  • pfi
                    • Jun 2016
                    • 274
                    • Country: Norway
                    #24
                    82 mm bearing : hub/spindle Inner dia ~ 45/43 mm
                    75mm bearing : hub/spindle Inner dia ~ 41/39 mm
                      • Dec 2017
                      • 5992
                      That's interesting pfi. The spindle could have been machined to fit the 75 mm bearing. Or maybe there is a 75 45/43 bearing out there.
                      • Rikki Kitto
                        • Feb 2010
                        • 6276
                        I'll get the spanner man to take pics and measurements for future info when we pull it all apart then the mystery will be solved peeps
                        • pfi
                          • Jun 2016
                          • 274
                          • Country: Norway
                          #27
                          "The spindle could have been machined to fit the 75 mm bearing,"
                          Possible but not advisable ?
                          Driveshaft OD 82mm bearing ~31mm, 75mm bearing ~27mm ...
                          If it's "a 75 45/43 bearing out there" it'd be nice !
                          more likely a B3 carrier machined to take a S2/RS2(Avant) 82mm bearing ?
                          • Rikki Kitto
                            • Feb 2010
                            • 6276
                            All will be revealed
                            • Rikki Kitto
                              • Feb 2010
                              • 6276
                              OK bearings for front are 82mm/ 45mm/43mm
                              Rear 75mm/ 41mm/39mm
                              so defo RS2 front and rear
                              • Rikki Kitto
                                • Feb 2010
                                • 6276
