RS2 rear wheel bearings
  • Rikki Kitto
    • Feb 2010
    • 6276
    • Rikki Kitto
      • Feb 2010
      • 6276
      !!!help me please!!!
      • Rikki Kitto
        • Feb 2010
        • 6276
        Originally posted by B5NUT
        Part number of the rear wheel bearing and it's still available at a silly £136 from Audi
        NLA since 2021
        • pfi
          • Jun 2016
          • 274
          • Country: Norway
          #34
          Originally posted by Rikki Kitto
          OK bearings for front are 82mm/ 45mm/43mm
          Rear 75mm/ 41mm/39mm
          so defo RS2 front and rear
          RS2 (and s2 Avant/Sedan (B4)) uses 82mm bearings front and rear.
          std RS2 rear hub doesn't fit in a 75mm so must have been machined.
          but, if You've measured rear to be 41/39 You may use a std s2 (coupe) rear 75mm bearing
          In front You can use a std s2 (front) 82mm bearing
          Original bearings part# may be NLA but plenty of alternatives out there ...
          • rxl
            • 1913
            rs2 uses SKF VKBA1356 wheel bearing. dont know how your rear hubs are maschined or just the hub itself comes from another car. best option to order 2 coupe ones and 2 rs2 ones. one of those will fit and another you can return.
            • pfi
              • Jun 2016
              • 274
              • Country: Norway
              #36
              Search for alternatives to VKBA 1356 :
              443498625A / 4A0498625 / 4D0407625E / 893498625E / 1D0498625B / 443498625F / 4B0498625A / 893498625C / 8D0498625B
              • B5NUT
                • Sep 2021
                • 1071
                NLA since 2021
                Thats very strange ETKA still lists them as a valid part
                A quick search on that part number on ebay and there are a few new old stock "Genuine Audi" bearing listed.
                • rxl
                  • 1913
                  Dont over pay I used the same ones as abive for my rs2
                  • Rikki Kitto
                    • Feb 2010
                    • 6276
                    Thanks guys must be the TPS guy not been arsed to look it up properly
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      As I've mentioned to you in the past it's hit and miss who you get at our local TPS, there's two old members of staff who are super helpful and will get you a part if available even if it means going on back order from Germany...
                      Where as there's also there complete moron who seem to be incapabable of finding anything for a car older than B6, it's alsmost like they simply can't be bothered to put stuff on a back order.
                      Jim got a full set of brand spanking new lower Coupe door trims after a long chat with Simon, who's probably the most helpful member of staff, he had to wait a month for them but the full set set cost less than £250.
                      I still have a set of Coupe door cards for you, I could end send them in a consignment of two packages for less than £40 now Parcelforce have dropped their prices again.
                      1990 B3 2.0 80 quattro.
                      1992 C4 2.8 Avant quattro
                      1994 MTM RS2.
                      1998 B5 TDI quattro Sport.
                      2000 B5 TQS.
                      • Rikki Kitto
                        • Feb 2010
                        • 6276
                        cheers bro I will defo get over t see ya one day as long as you OK storing them I've ordered the front bearings off eBay has anyone got part numbers for the rear ones
                        • K Simmonds
                          • Dec 2007
                          • 7627
                          That fine mate, they don't take up a lot of room and aren't in the way.
                          1994 MTM RS2.
                          2000 B5 TQS.
                          • Rikki Kitto
                            • Feb 2010
                            • 6276
                            Some pics of rear thingy
                            • rxl
                              • 1913
                              and did they fit`?
                              • Rikki Kitto
                                • Feb 2010
                                • 6276
                                Not tried yet spanner man doin it soon
