Because if you have an airlock all you'll get is cold air in the cabin.
WANTED - Complete S2 or RS2 Engine for MTM 500hp Projekt!
This is perfectly right.
you can have it on cold if you like, you just need to bleed the coolant system well.japanischer industriabfall nein danke!!
www.rackeltrim.se Icelandic DivisionComment
Dudes, I love you! I will let you know how I get on. Was thinking it might just be easier to buy a whole S2 and tune the engine up with the MTM items, then stick some RS2 bits on it. I ssem to be having not much luck with finding a rs2 engine and gearbox!Comment
Is it a stronger unit?
Is it a strait fit?
Is the s4 gearbox ratios suitable for the RS2?
tick tick tick.............u got me thinking now!Comment
Basically mate put your money away, do some research speak to someone like Aelred and really decide on your next course of action before you end up spending money on a spec you wont be happy with.
Yes the S4 boxes are suppose to be stronger as they take 500 bhp all day long.Comment
if it were me i would look out for a cheap UrS4(have seen them for less than a 1K) and strip the engine and box out of it and start from there93 S2 Avant Parting
91 URQ RR
02 A4 tdi AvantComment
'93 S4 Avant now back on the road complete with new shiny go faster bits.Comment
The heater controls DO affect the flow of coolant to the matrix
The flow of air over the matrix is to transfer the air temprature regulated by the matrix to the passenger cabin
The reason you need to turn the heating control to hottest setting is to allow the flow
of water to enter the heater matrix to complete the water circuit and purge any air.
The heater control is conected to a water flow control valve (located on the water inlet line to the heater matrix from back of cylinder nead ) by a mechanical cable.Dez
Never did overtime until i purchased........s2
