Fumoto Drain valve
  • europeanme
    • Oct 2005
    • 3817
    Fumoto Drain valve
    a long shot as I remember the group buy from a while back but gotta ask...
    Mike
  • s2driveruk
    • 12696
    cant you buy them direct still? Are a bloody good part actually, definately recommend them
    1992 3b S2 Coupe
    • europeanme
      • Oct 2005
      • 3817
      lets hope so....
      • Tonks4x4
        • Nov 2005
        • 3062
        Fumoto Valve
        If a group buy for this item can be arranged again. Who would be interested???
        I have made a few enquiries of different suppliers....
        Audi Nut!!!
        • AUDIS2avant
          • Jan 2009
          • 670
          • Country: Denmark
          What is this??
            Originally posted by AUDIS2avant
            What is this??
            google
            • Tonks4x4
              • Nov 2005
              • 3062
              What is this??
              This is a drain tap to fit the Audi sump to stop all the hastle of leaky sump bungs, Seized in sump bungs, Rounded off sump bungs and all the associated pain and hastle with removing them.....
              Audi Nut!!!
              • s2driveruk
                • 12696
                1992 3b S2 Coupe
                  I've had one my Coupe and Avant, well worth the money!
                  • saltinot
                    • May 2004
                    • 1946
                    Got one on the B2. Works great, saves time, crush washers, and you can drain your oil using only your pinky finger. I should get a couple for the S-cars too.
                    • lind4hl
                      • Jul 2008
                      • 2465
                      i´m in on groupbuy for sure!
                      • Bram
                        • Aug 2006
                        • 2582
                        I decided not to take one as it leaves the last part of engine particles oil junk at the bottom of your sump. The Fumoto drain simply does not allow you to get the last drops of oil junk out of your engine. No Fumoto for me.
                        • Josh-stateside
                          • 741
                          I moved the stock fan sensor to the thermostat to lower radiator hose and i'm putting a fumuto in the stock fan sensor position. I figured why not and iv'e got a v6 harness not a s2 so it helps with wire placement.
                          • s2driveruk
                            • 12696
                            Thats an interesting statement, exactly how much crud is collected there i your experience?
                            1992 3b S2 Coupe
                            • sjw185
                              • 1175
                              Still a great way of draining oil and you can take it off or jack the car up to get the dregs oot
                              cheers
