ur s4/s6 rear abs sensor
  • roysterFR
    • Dec 2010
    • 140
    I am looking for rear abs sensor for ur s4/s6 used or if anyone has spare new one? Thanks
  • quattrostyle
    • Oct 2006
    • 6229
    Got a complete set if you get stuck
      Not sure why or if it makes a difference but there was a part number change from the 92 and 93 UrS4 to the 94 UrS4. Items 11 below. 4A0927807C to PN 150000, 4A0927807E from RN 000001 to the end of the 97 UrS6 run. Item 12 is the coppery sleeve used to hold the ABS sensor in the wheel bearing housing.
      • A1QSHIP
        • Aug 2004
        • 975
        It has to do with the additional rubber mounting piece on ABS sensor cable fitted to the '92-'93 Urs. It connected in to an additional bracket as fitted for the rear anti-roll bar. This kept the ABS cable from contacting the anti-roll bar drop links.
        Dave I will post up pictures when I get a chance.
        HTH, Chris
        "Nulla tenaci invia est via"
          Originally posted by A1QSHIP
          It has to do with the additional rubber mounting piece on ABS sensor cable fitted to the '92-'93 Urs. It connected in to an additional bracket as fitted for the rear anti-roll bar. This kept the ABS cable from contacting the anti-roll bar drop links. Dave I will post up pictures when I get a chance. HTH, Chris
          Thanks Chris. I will look for your photos.
          • roysterFR
            • Dec 2010
            • 140
            Abs sensors
            Thanks for responses all sorted now
            • quattrostyle
              • Oct 2006
              • 6229
              Happy dealing with you Roy
