I am looking for rear abs sensor for ur s4/s6 used or if anyone has spare new one? Thanks
ur s4/s6 rear abs sensor
Not sure why or if it makes a difference but there was a part number change from the 92 and 93 UrS4 to the 94 UrS4. Items 11 below. 4A0927807C to PN 150000, 4A0927807E from RN 000001 to the end of the 97 UrS6 run. Item 12 is the coppery sleeve used to hold the ABS sensor in the wheel bearing housing.
It has to do with the additional rubber mounting piece on ABS sensor cable fitted to the '92-'93 Urs. It connected in to an additional bracket as fitted for the rear anti-roll bar. This kept the ABS cable from contacting the anti-roll bar drop links.Not sure why or if it makes a difference but there was a part number change from the 92 and 93 UrS4 to the 94 UrS4. Items 11 below. 4A0927807C to PN 150000, 4A0927807E from RN 000001 to the end of the 97 UrS6 run. Item 12 is the coppery sleeve used to hold the ABS sensor in the wheel bearing housing.
Dave I will post up pictures when I get a chance.
HTH, Chris"Nulla tenaci invia est via"Comment
Thanks Chris. I will look for your photos.It has to do with the additional rubber mounting piece on ABS sensor cable fitted to the '92-'93 Urs. It connected in to an additional bracket as fitted for the rear anti-roll bar. This kept the ABS cable from contacting the anti-roll bar drop links. Dave I will post up pictures when I get a chance. HTH, ChrisRS2'd 93 UrS4 5 spd sedan
