Coil packs
  • Rikki Kitto
    • Feb 2010
    • 6276
    Coil packs
    Don't suppose anyone has the odd 2 laying about, 2 of mine seem to be playing up?
  • Colesy
    • Feb 2009
    • 2981
    Is it definitely the coil packs and not one of the POS's? Seems strange that two would play up at once. Easy to check by just swapping the POS wires over.
    • Rikki Kitto
      • Feb 2010
      • 6276
      POS wire? how to swap, I'm not sure it's the packs because they were fine before engine swap
      • rynaqui
        • Mar 2012
        • 2752
        • Country: Malta
        If you left them in a damp area for a while it could have caused some damage to the coilpacks. Other than that possibly bad wiring (brittle)
        1996 S2 ABY Silver
          Power Output Stage (POS) info
          POS Diagnostics:
          POS Pin Swapping:
          General N122 and N127 info:
          • Rikki Kitto
            • Feb 2010
            • 6276
            Cheers guys I'll check this out first, thought it seemed strange that 2 went down together
            • Pembo
              • Aug 2004
              • 295
              I have a few spare POS available as I've swapped to coil over packs. Is £25 each reasonable?
              Pembo
              quattro - Original 4WD rallying
              Rally Car photos
              • Wrath
                • Jan 2011
                • 779
                Had hesitation under idle and no boost but was fine at high rev and high boost 1,4-1,5 , was one of my POS that was burnt, changed them to some spare and the car runs good. Not a common fault but it happens
                1995 Audi S6 - AAN (~350hp)
                2008 BMW 530xd (235hp)
                2011 KTM 990 SMR - custom tuned (120whp)
                • benntenn67
                  • Jun 2009
                  • 859
                  Replaced one of my POS a year or so ago, due to a missfire - they break up inside probably down to engine bay heat? on that theory, I used some of that heat dissipating grease that they use when building computers, I put it on the back of the POS before bolting it to its mounting
                  Audi S2 Coupe 1995
                  VW Passat GL5 (hatch) 1986
                  Carrera Subway 8
                  • Rikki Kitto
                    • Feb 2010
                    • 6276
                    Let you know if I need em bud
                    • Wrath
                      • Jan 2011
                      • 779
                      My spare had that already, dont know if they should have it!? The one I replaced didnt, and I felt a burning rubber smell whe hesitation occured... but now it cured,
                        Some pertinent info shown here (linked out my POS post linked above):
                        • benntenn67
                          • Jun 2009
                          • 859
                          http://www.urq20v.com/My_other_cars/S6/POS/S6POS.htm
                          Great minds an all that adding extra heat sinks is something I will also do
                          Audi S2 Coupe 1995
                          Carrera Subway 8
                          • cooperquattro
                            • Jan 2011
                            • 815
                            i have 5 coils from my working engine and also the POS if needed
                            • Rikki Kitto
                              • Feb 2010
                              • 6276
                              What do you want for 2 coils?
