Anyone got one for sale or able to make me a set, just want to be able to straight swap for the standard set up
Coil pack upgrade
Tags: None
Ask Alex.... Error... On here. He made mine and it's perfect. Looks original and was a lot cheaper than buying one from 034 or the likes. Plus he's a true gent and always willing to help and even follows up afterwards to make sure I was happy with it, it fitted well and was all good. He even helped with telling how to install...Comment
TWINCHARGED power,zero lag
AEM W/M injectionComment
are these the same thing?
AAN engined UrS4s and UrS6s, as well as ABY/ADU engined Audi S2s and RS2s have notoriously poor coil power output stages endearingly called "POS's". Often intermittent or premature failure will manifest in a hesitation or miss under acceleration. Do away the costly POS and replacement coils with updated VAG coils from the 2.0T FSI with built in power stages. Fully plug-in harness, all connectors feature OEM quality, automotive grade wiring, literally takes minutes to install and is totally reversible should it ever need to be. Includes instructions to modify OEM 2.0T FSI coils to literally pop right in. Tested for performance compatibility up to normal "RS2 power levels" in the 275hp range.1997 Audi S6 - The Purple Helmet!Comment
yes,i think so,only the red coils come from v8
i made the wireloom my self and used v8 red coils from 4.2 v8 s4 b6Attached Filesaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
very nice indeed
so you don't actually need the "20v tuirbo" lid to hold these coils in place? i had always thought that the lid would help fry the coils over time . . .
the coils have a rubber hose that just fit in the sparkplugholes so it's a direct fit
i have adapt my 20v cover for cooling but now drive without itaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
Good links guys cheers, like the idea of cutting the cam cover was thinking of maybe getting one made up out of stainless or titanium😳 decided to get a loom of Mr Error404 and coils from ECPComment
This is just the harness, doesn't include the coils.Comment
