S4/6 rear ABS sensors 4A0 927 807 E
  • shaun5
    • 1610
    Im doing a suspension rebuild on my S6 so changing all the wheel bearings, unfortunately you have to remove the ABS sensors on the rear and they are rusted in so the only way to remove them is to destroy them
    Anybody got any? part number 4A0 927 807 E
    Pretty sure only ones from a A6 quattro will fit.
  • shaun5
    • 1610
    Bump
    • Liam Gallagher
      • Nov 2003
      • 52
      • Home: Canada Current: Scotland
      The generic ones from eBay seem to work well. The one I purchased was listed for a C5 A6, IIRC, it worked fine. I just had to solder on the connector from the old sensor.
      Audi B3/B4 Photography group
      • roysterFR
        • Dec 2010
        • 140
        Abs sensors
        You can change bearings with sensor in just remove cable from car under rear seat. The bearing doesn't damage it when pressed out
        • shaun5
          • 1610
          now you tell me it doesnt look like the bearings will go past the sensor without damaging it not on the rears any how.
          • shaun5
            • 1610
            Have you got a link for them
            • roysterFR
              • Dec 2010
              • 140
              They deffinitely go past have changed about 8 there are sensors cheap on eBay that will straight fit have a search through Audi c4 etc
              • shaun5
                • 1610
                just pushed my bearings out and you are correct you dont need to remove them
                Anyway has anybody got any
                • shaun5
                  • 1610
                  Bump. Need a couple of these ASAP, got the week off and want to fit all my refurbed parts.
