ABY AAN Engine wanted
  • roger shaw
    • Sep 2008
    • 129
    Hi
    Anybody got an engine for sale
    Prefer in the UK
    Require sump/block/pistons/crank/oil pump
    Regards
    Roger
    07976844112
  • nicksonmsport
    • Mar 2014
    • 380
    I have one, in uk. damage bottom end but perfectly serviceable.
    the bottom end is aby, it has good crank, rods and pistons. but the block has a bit of wear in 2 cylinders. one cylinder has a sort of dent in the bore wall, caused by broken piston ring which dug into wall. only 0.5mm deep so an overbore using new pistons would be fine only 1mm oversize. or you could keep the original pistons and have the block bored out and sleeved to maintain original bore measurements.
    I don't have the sump, but it does have oil pump.
    perfect for rebuild, or an engine that's going big power as you can fit oversize forged pistons etc
    £350 as it stands
    regards
    • LHD_Kid
      • May 2006
      • 3696
      I have a sump if needed...
