Sunroof panel switch
  • Rikki Kitto
    • Feb 2010
    • 6276
    Need a good control panel any colour not pre select type and must have all clips and lugs intact, I've got three with bits broken so must be a good un
  • Rikki Kitto
    • Feb 2010
    • 6276
    Bumpster
    • Rikki Kitto
      • Feb 2010
      • 6276
      • Colesy
        • Feb 2009
        • 2981
        I have a good light grey one which I snapped the clips off to fix a preselect!
        You really should try some epoxy resin to refit the clips, I have two with both clips epoxied back on and they are holding well. HTH.
        • Rikki Kitto
          • Feb 2010
          • 6276
          Spring clips are fine it's the stupid little plastic tags on the opposite end that are all snapped off
          • Colesy
            • Feb 2009
            • 2981
            That end the clips are fine I think, I'll check and let you know.
            • Rikki Kitto
              • Feb 2010
              • 6276
              • Rikki Kitto
                • Feb 2010
                • 6276
                ebay one Sold
                any more offers peeps
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  OK managed to get the one of ebay in great condition but guess what it's wrong sizeDidn't even realise that there was different sizes for our coupes' still looking peeps, just re read the add it's an avant one anyone need a good avant sunroof control panel in grey
                    I fixed my coupe one the other day with a couple of bits of perforated strip glued on to replace the missing plastic hooks. Seems to have worked a treat.
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      MMM any pics
                        Originally posted by Rikki Kitto
                        MMM any pics
                        I'll take some tomorrow
                        I'll also have a look for a panel as I should have a normal coupe one somewhere
                        Mine is preselect type
                        I didn't know coupe and avant were different either...
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          I wasn't either think I might have just got sent a random covershame because it's in really good nik
                            Found the spare panel, it has 2 of the 3 tabs remaining at the front and one repair at the screen end. You are welcome to this if it's useful to you. It came from a V6 Coupe.
                            There's a couple of comparisons with my S2 preselect panel. The pic at the bottom shows the way I mended the hooks, I just did one each side.
                            • Rikki Kitto
                              • Feb 2010
                              • 6276
                              Cheers bud I'll have a go at fixing clips onto mine mine I've got a pic to work from
