I just typed up a huge reply and the computer crashed. I'll keep it simple this time.
I was planning on running Autronic sm2 on my audi, but I've been a bit turned off by there very expensive wideband o2. You can't use the autotune feature without their wideband, so they have the market cornered.
I have since been looking around and found that AEM is a good option for us 5 cylinder guys. I was talking to a AEM engineering the other day on their forum and he recommended the mitsu evo 8 ecu. It has 5 coil drivers and 10 injector drivers which is perfect for us 5 cylinder guys. Plus, they have an option of a internal wideband analyzer. It comes with the sensor also, so you have no problems with compatability. All this for just $1700 USD. You can get the non wide band ecu for ~$1350.
If you want more info, visit the tech forum over at
http://www.aempower.com/default.asp
http://forum.aempower.com/bbs/login.php
The evo 8 with intergrated wideband is part number 30-1313U
A schematic can be found at:
http://forum.aempower.com/bbs/download.php?id=1223
Best Regards,
Justin Olson
Best Regards,
Justin Olson
