Hello
Need some Help with ignition map, run 98 oct and gt3071 ar63exhaust,440cc inj 3" exhaust, no cat, car its very very slow.. go better with gt3071 chip.. thats bad... need some Help or Maby share a map?
This gallery has 1 photos.
if you run 98ron then look to take for a safe setup 1 degree for ever psi or so. thas the old rough rule. so if you get 30 odd degrees start at 15 or so for a bar and work up adding timing. what vas says is true. think I have 20 odd at 2bar boost.
