3B ECU Modification
  • ride0238
    • May 2017
    • 41
    3B ECU Modification
    I am looking for advice on how to proceed if I want to upgrade the ECU on my S2 3B ECU?
  • pasbogdan
    • Sep 2009
    • 1160
    • Country: Romania
    What do you mean by upgrade?
    • ride0238
      • May 2017
      • 41
      I mean chipping or possibly changing to coils versus a distributor. Looking for a little more horsepower.
      • shorty_94
        • Dec 2015
        • 60
        By only upgrading the distributor to coils, you won't get any single HP more out of your engine.
        The problem at 3B's ECU ist the 200 kPa MAP-Sensor. Without changing it, you are extremely limited.
        '95 Audi S2 Avant
        '92 Audi Coupe T89 quattro 2.3E
        • ride0238
          • May 2017
          • 41
          What's involved in making that change?
          • shorty_94
            • Dec 2015
            • 60
            You have to solder in a MAP sensor from ABY's ECU (250 kPa = 1.5 bar above atmosphere).
            It's the black "box" with the hose.
            After that you can change your EEPROM's ("chips") and get 260 - 280 HP out of it, depending on which software you buy (software for ABY or ADU doesn't work without changing some other hardware!!)
            This gallery has 1 photos.
            '95 Audi S2 Avant
            • prj
              • Mar 2010
              • 6308
              Software for ABY/ADU won't work without changing the ECU lol.
              • shorty_94
                • Dec 2015
                • 60
                And ECU is also part of the hardware
                I just wanted him to know, that he can't use ABY/ADU software just because of changing the MAP Sensor.
                '95 Audi S2 Avant
                • ride0238
                  • May 2017
                  • 41
                  Can I use any aftermarket chips? 034 or 2 Bennett?
                  • shorty_94
                    • Dec 2015
                    • 60
                    You won't find any OEM tuning EEPROM's for the old Audi's, except (semi original) SMS Revo software
                    '95 Audi S2 Avant
