Hi all,
So I'm doing the final preparations before engine start on the newly installed MaxxECU.
One of the final check points is to figure out the trigger angle.
I locked the ignition + disabled fuel and used an advance timing light to make bottom (harmonic dampener) and top (cam sprocket) 0 marks line up.
I had to advance the timing light 7 degrees to achieve this.
All good this far.
Now comes the question.
Looking at the delivered AAN/ABY/ADU basic settings file from MaxxECU should I subtract 58 with 7 degrees (=51) or add 7 to 58 (=65)?
Or do I simply replace 58 with 7 degrees?
See included screenshot of settings page.
I'm having trouble finding this using my limited google and forum search skills.
Any BTDT?
Thanks
All good this far.
Any BTDT?
Thanks
