MaxxECU S2 Crank and Cam Sensor Settings - Need Confirmation
Manifests as a stutter, almost like a misfire?
Have you set your arming thresholds with the trigger logger/scope?
Arming voltages look a little high potentially
I just found out they converted to single mass flywheel and kept the spacer between the trans and block. Sensor might be too fat away from flywheel at the moment. They will remove the spacer, log and report back. If problem persists I will find a way to set the thresholds.
In the meantime I feel like polarity for both sensors should be "rising"... what you see there is what they sent me.
I would expect an issue in low engine speed when the distance is too low cause the voltage raises with higher engine speed from the VR sensor. I had similar issues at the megasquirt with wrong polarity of the sensor for example but I don't know the MaxEcuu and how the VR sensor signal is used internal..
