MaxxECU S2 Crank and Cam Sensor Settings - Need Confirmation
  • mushasho!
    • Apr 2007
    • 163
    Would like to confirm I've have the proper setting loaded in MaxxEcu
    Audi S2
    3B SMF Clutch
    Stock Sensors
    Chasing a "Lost Sync Count" issue, remotely through logs.
    _Rubí_
    Manifests as a stutter, almost like a misfire?
    Have you set your arming thresholds with the trigger logger/scope?
    Arming voltages look a little high potentially
    • mushasho!
      • Apr 2007
      • 163
      I just found out they converted to single mass flywheel and kept the spacer between the trans and block. Sensor might be too fat away from flywheel at the moment. They will remove the spacer, log and report back. If problem persists I will find a way to set the thresholds.
      In the meantime I feel like polarity for both sensors should be "rising"... what you see there is what they sent me.
      _Rubí_
      • Acki
        • Mar 2014
        • 302
        I would expect an issue in low engine speed when the distance is too low cause the voltage raises with higher engine speed from the VR sensor. I had similar issues at the megasquirt with wrong polarity of the sensor for example but I don't know the MaxEcuu and how the VR sensor signal is used internal..
          I also saw a trigger issue recently where the ECU / sensors were grounded incorrectly, on the chassis rather than the block/head.
