In the future i would be looking to tune my s2 3b,I would be looking for around 400bhp. my concern would be tuning a old engine without re building and are the gearbox and clutch good for this power and torque? Ive tuned cars in the past,I had a s4 b8 with around 460bhp but Im not that clued up on these engines. Advice welcome
The path to 400bhp
Gearbox is not really up to the job and the clutch will be a weakspot too....then there is the dizzy, rods could be a problem.
if you are going to go to 400 bhp, you need to open it up and prepare it...otherwise could be an expensive mistake in my view. Lots of detail on here for people that have tuned the 3b...good lick, the results if done right should be worth the colegate grinsigpic
1992 3b S2 Coupe
The 3B had a paper head gasket, that needs replacing with the later all metal type if you’re going for more power.
If the head is off you could replace shells rings and also rods if you want lots of boost low down, stock rods are ok on an RS2 spec car up to 380 ish ( it’s torque that bends rods anyway)
The 3B is also limited in tuning because of the dizzy, converting to five coils can be done by doing the ECU connector “pin swap” and adding a few wires so you can use either RS2 type software in the later type ECU or go aftermarket.
You also need to decide if you want the car to be nice to drive. The standard car has a lovely luxurious feel to it and with a nice stage one chipset can be fun too. If you go for lots of power and start stiffening it up and polybushing everything you’ll end up with a quick car that’s horrible and crashy on our crappy roads.
Anyway gave a read of my coupe thread!
Originally posted by newsh View PostThe 3B had a paper head gasket, that needs replacing with the later all metal type if you’re going for more power.
Originally posted by hilly82 View Post
thanks some good points there. I guess doing the ecu pin swap is a good place to start then i can decide which way to go from there. maybe 400bhp is too high dont want to ruin the drive of the car maybe 300 bhp might be more sensible. Is there a guide on the coil conversion? Thanks for your help people
400 is not too hard, a tuned RS2 spec car is almost there, the jump to 500 is big though, at that point you need forged rods
Important to find out how healthy your car is, get a boost gauge on it to be sure how much it’s making.
- 1 like
