Who's runing VEMS????
  • 20vQC
    • Aug 2007
    • 684
    • Current: Italy
    Who is running the 5cyl with the VEMS electronic management?? I was thinking to get the MegaSquirt ECU but a few people told me is not a good choice. So I read about the VEMS and seems to be nice and reliable with a little hifgher price than the MS... but I'd like to know if somebody is already using it. Thanks mates!
    - Looking for a S2
    - Lancia Dedra HF turbo i.e. (4sale)
    - Typ89 Coupè quattro, 20Vt AAN, VEMS, K24-7000@1.3bar (scrapped )
  • GazzaG60
    • 4133
    the search is friend.
    there are a couple of us that have a running vems car.
    • 20vQC
      • Aug 2007
      • 684
      • Current: Italy
      Hi bro! Hey and how is it go??? is the tune easy? how much did you pay in total??
      - Looking for a S2
      • GazzaG60
        • 4133
        best is to read my post on my car with vems.
        i will add anything to that as i got.
        the basics are
        easy install
        medium setup
        easy tuning.
        great running.
        • 20vQC
          • Aug 2007
          • 684
          • Current: Italy
          Nice bro!!! well I'll ask for your help as soon as I get the ECU and the engine of course hehe I hope to start my project in march of next year! Thanx a lot G60!!!
          - Looking for a S2
          • K7ERG
            • 1711
            Im running on Base map, just need to map it.
            Craig
            Audi A6 AEL 5cyl Quattro breaking.
            Audi A5 3.0tdi Quattro Stage 2
            07947385043
            • GazzaG60
              • 4133
              craig - hope you dont mind but i thought id reply to your pm here so others can read. i get asked lots of q's about vems and try to answer as best as possible.
              you need to ensure you have the same firmware as megatune. best to download a package with it all in. you need to also ensure you have the correct sort of map loaded for the intended config ie hi boost 12x12.
              once you have the correct loaded it should all talk. i use 1.1.23RC have done since the start. it works great. i dont use the idel valve or the N75 though. i run without idle control and with an EBC. hope that helps.
              when you load firware on it is supposed to backup the config and reapply but it didn't for me. i had to reload my map after.
              are you using USB? there are issues that some serial to usb converters dont work. i use straight serial and never an issue. the only problem ive had is when the plug pulled out during a firmware update adn i have to do a force reset using a paperclip on the 9 pin.
              ensure you get the download from VEMS. if you have tuned with megasquirt you will know this but if not.....in megatune you need to change the config files to deturmine the type of megasquirt you require and other things like temp readings and map sensor. in the vems compile its set already. get it from vems.hu
              • K7ERG
                • 1711
                Not a problem mate.
                12 x 12 high boost i am on.
                I use 1.1.23RC
                I am using USB so might have to get a serial cable.
                Just need some communication now.
                I will post my findings on this post.
                Craig
                07947385043
                • GazzaG60
                  • 4133
                  its simple to tune really too.
                  1. set req fuel
                  2. set crank pw
                  3. set afterstart
                  4. generate VE
                  5. Generate spark.
                  6. write lambda
                  drive.
                  make tweaks to warmup enrichment and also accel. twae VE and timing.
                  aim for 14.5-15.5:1 for cruise. i like lean off boost to give clean burn.
                  aim for 11-12:1 for boost.
                  add timing to cool EGT, remove to smoothen on the limit.
                  a WB02 and EGT gauge is well worth it.
                  a set of det cans is also useful.
                  use megamanual to seek setting advice. megasquirt may not be the best ECU but it has the best manual with the best support.
                  hope this helps
                  • a4kquattro
                    • Feb 2005
                    • 411
                    I like it so much, I sell them
                    I run VEMS on my S6 Avant, its a great system as others have mentioned. I ship all of my ECUs with firmware 1.1.27.
                    Marc Swanson
                    Proprietor, EFI Express
                    95.5 //S6 Avant
                    90' Coupe Quattro V8 4.2L twin turbo
                    93' //S4
                    83' UrQ
                    97' F250 7.3 diesel
                    • GazzaG60
                      • 4133
                      not only a user but a seller too now marc. good work. glad you liked it
                      • th.b.w.
                        • Nov 2006
                        • 98
                        Who has information.
                        I would like to change the 3b ignition on 5 ignition coils
                        This must have which functions ?
                        Thomas
