pnp Vems offer
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Originally posted by peter_jensen
    Vems also offers many other advantages as lunch control
    Do they have dinner control? As far I understand, after you pay for it, it limits amount of money you spend for food .
    Sorry for offtopic, but somehow that looked too funny this morning .
    Sau
    • dkw_dude
      • 555
      • Country: Norway
      Hi, this is interesting..
      If i install this on my 3B with electronic climate control, will it work ok? Does it read the "compressor on" signal from the ECC and compensate for this, preventing idle from dropping?
      If I buy this system, and later on want to convert to direct fire with 5 coils, will this be possible (by modifying the wiring and adding coils, and some software changes?)
      Cheers Leif-Helge
      Yes documentation is a good thing but with Vems PNP does not require as much as it is quite easy to install.
      1: demount the old ecu
      2: install the included cable (1 M) for wideband lambda probe
      3: switch-violet and red wire in the plug to crank home vr sensor
      4: connect Vems to monotronic 55-pin connector and boost pipeline
      5: fit the plug in to wideband sensor
      6: start the engine and the installation is complete
      Regards Peter
      Leif-Helge
      -91 S2 VEMS and Comp Turbo
      -12 B** 530XD Touring "S2 parts transporter, and daily driver"
      • Rusty
        • 18953
        That's sweet. Wideband Lambada is a very useful tool when it works. WHo tunes VEMS in the UK or is it a DIY job over here?
        • peter_jensen
          • 103
          • Country: Denmark
          VEMS PnP
          Hi
          Climate control will work and Vems will prevent the engine stall but it takes some time to adjust.
          The only deference is you have to turn of the Climate control Manuel when running high rpm/race to prevent destroying the pump.
          There is more that can tune Vems in the UK but the point is that you can tuner
          the car by you self like 95% of all Vems users due.
          When ordering Vems the ecu is calibrated and installed with a standard (S2) working setup so you can tune from this step.
          Yes it is possible to fit coil on plug later if you like.
          Thanx Peter
          Vems since 2004
          • GazzaG60
            • 4133
            ill send a basemap to people who need one who dont have one if they like. you can find them on the wiki or from the supplier also.
            vems is one of the easier to tune ECU's. things like LINKECU take an age to gert right
