VEMS firmware versions
  • Bram
    • Aug 2006
    • 2582
    VEMStune crashes even without being connected to the ECU. Maybe it's time for me to check out the linux version of VEMStune
      To be honest it doesn't crash when entering fields on my old laptop I have for mapping / vagcom it's more stable
      • GazzaG60
        • 4133
        oldies but goodies eh.
        i have tested on
        dell d600,D610,D620,D630 - all good
        ibm with usb -the one martyn had. not good
        toshiba satalite, sat pro. old grey and old blach ones - 4200 series 4090, they work too.
        problems with vems will come next 2 years as old laptops die and we are stuck with usb. vems need a good usb box like LINKECU.
          Or do the intelligent thing and develop a USB connrection
          • GazzaG60
            • 4133
            sure it cant be far off. hopefully not an ecu change though.
            VEMS may benifit from the extra bandwidth too of USB.
            were a dell house here. i only buy dell now. i currently use a french D610. lol good job i can operate a pc in french.
            sure somebody will come up with something soon.
            • A80Avant
              • 10873
              • Country: Greece
              #111
              my laptop is old so carries a serial port. eventually im going to keep that for tuning purposes, and get a proper new one in the future
              however i do wish there was a possibility to make a small 8inch one with serial port and windows xp. no need of a cd/dvd on it, just a small hard drive and a bit of memory to keep it from crashing.
              • GazzaG60
                • 4133
                i have an old toshiba libretto with a docker. its around half the size of the glovebox, runs windows 95 and thats about it.
                never tried it with vems. ill stick with the D610.
                • A80Avant
                  • 10873
                  • Country: Greece
                  #113
                  as it has been updated in Jamo's vems page, version 1.1.63 is going to be released with the correction on kpa vs kpa! yeah!
                    On my page It says there is a new version of vemstune to correct the issue in a released version after the date 2009-11-11.
                    There is a reference to 1.1.63 as the boost tables have been moved to a different section which means the error wouldn't occur again in later firmware either.
                    • A80Avant
                      • 10873
                      • Country: Greece
                      #115
                      yes that is what i thought, and i understood that the 1.1.63 will be released sometime after 11/11/09
                        New VEMSTune out http://www.vems.hu/download/v3gui/
                        • Bram
                          • Aug 2006
                          • 2582
                          Originally posted by Jamo
                          downloading it
                          • A80Avant
                            • 10873
                            • Country: Greece
                            #118
                            just did it!
                            • A80Avant
                              • 10873
                              • Country: Greece
                              #119
                              And yes RPM is corrected!!!!
                              • AllarN
                                • Feb 2007
                                • 151
                                I Had 1.1.27 in my old S4, works great with stock sensors and reving 7500rpm.
