VEMS and EGT
  • Billman
    • 4129
    VEMS and EGT
    Have some issues lately with my EGT sensor. I see always up and down 0 and them 1125 Celcious. nothing in between. Is the sensor faulty or should i check something else?
    Go Holset or Go RS4
  • Billman
    • 4129
    ? Nobody
    Go Holset or Go RS4
    • diesel des
      • 3896
      What does it do with the sensor disconnected.
      • Billman
        • 4129
        Interesting, I didn't check but I suppose it shows only 0??
        Go Holset or Go RS4
        • terrybullwon
          • Mar 2006
          • 8782
          Can you measure DC voltage ? it changes appr +1mV for +25C - when you heat the tip this should tell you if your probe is dead or you have it in the wrong mode
          Chef
          • ranz
            • May 2006
            • 119
            No, it should show you 1150 or something like that.
            Is your sensor 2mm or 6mm one? If it´s 2mm one, then most likely it´s broken, usually from that spot where you fixed it´s position), try to get the sensor out from the manifold/downpipe.
            Or, your lucky and there is short circuit inside the connection plug or somwhere on the cable (because at short circuit it shows 0, without connection 1150).
            • Billman
              • 4129
              mine shows 0-1125 every 2 seconds. I have the 6mm sensor....
              Go Holset or Go RS4
              • diesel des
                • 3896
                I think that mine shows 0 when disconnected... will check tomorrow night
                • terrybullwon
                  • Mar 2006
                  • 8782
                  i think you should read my post again
                  Chef
                  • Billman
                    • 4129
                    did it, i dont get anything! I think my sensor is gone!
                    Go Holset or Go RS4
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      yes i had three bad ones
                      Chef
                      • GazzaG60
                        • 4133
                        my probe is doing low readings at the moment.
                        i have a thinker probe./ the wires are the weak spot not the probe tips on those
                        • Billman
                          • 4129
                          Yes I think my busted where the cables start after the sensor.
                          Go Holset or Go RS4
                          • GazzaG60
                            • 4133
                            does it touch the bonnet? mine does slightly and over time rubbed through the casing breaking wires
                            • Billman
                              • 4129
                              Don't seem to but maye during the engine swap it had to move here and there...maybe it happened that way.
                              Go Holset or Go RS4
