Have some issues lately with my EGT sensor. I see always up and down 0 and them 1125 Celcious. nothing in between. Is the sensor faulty or should i check something else?
VEMS and EGT
Can you measure DC voltage ? it changes appr +1mV for +25C - when you heat the tip this should tell you if your probe is dead or you have it in the wrong modeChefComment
No, it should show you 1150 or something like that.
Is your sensor 2mm or 6mm one? If it´s 2mm one, then most likely it´s broken, usually from that spot where you fixed it´s position), try to get the sensor out from the manifold/downpipe.
Or, your lucky and there is short circuit inside the connection plug or somwhere on the cable (because at short circuit it shows 0, without connection 1150).Comment
