knock, knock who's going to tune my s2 for me?
  • John Reavey
    • Nov 2008
    • 40
    Hi Shane, I used Martin Tracy in Enfield to Dyno the coupe shortly after getting it.
    Not that I would know, but he seams to know his stuff. His is based in the Industrial Estate on the Trim Road in Enfield.
    • s2_wot
      • Aug 2006
      • 2178
      Originally posted by Jonnybravo
      I use a AEM wideband, their not massively expensive but are known to be very good.
      do I need one of those guages in the car or will the ecu interpret the output.
      Didn't know you dyno'd her, what sort of figures did you get back? How the mfts?
      Shane
      • Jonnybravo
        • Aug 2008
        • 2051
        If your using a stock ecu I don't think there is a input for it.
        Most aftermarket widebands the AEM included come with a gauge so you can simply monitor it from there.
        Its definitely something worth having in a turbo car.
        • s2_wot
          • Aug 2006
          • 2178
          The shopping list grows.. at least I know in time to get the bung into the downpipe before the cats.
          Shane
          • Jonnybravo
            • Aug 2008
            • 2051
            Speak to Paul if he is mapping it, I am sure he can offer you the info you need.
            You can spend a fortune on gauges to monitor things but a wideband and maybe a EGT probe gives enough info to keep things safe IMO.
            • John Reavey
              • Nov 2008
              • 40
              Hi Shane,
              got 240bhp on Martin's Dyno! He thought a stronger wastegate spring might be giving higher than expected result? MFTS is knackered, I just left #4 terminal unplugged, so no more Autocheck beep on start up! Will get round to replacing it sometime soon. Temp gauge is fine and showing normal temps! Got the dreaded 53 code on the autocheck screen after re-fitting the clocks, but figured it out and sorted, left side knob was pushing against the button for setting max speed warning/autocheck sequence at rear of clocks!
              John
              • mcandmar
                • Apr 2004
                • 5118
                I suspected the dyno is a little optimistic so thats probably spot on for a stock motor. My 7A made 174bhp which seemed a little too healthy for an engine thats clocked up over 300k, even with a rebuilt cyl head.
                91CQ20v - Gone to a new home
                93UR-S4 - The Magic Carpet
                94S2Bus - The Emerald Express
                • s2_wot
                  • Aug 2006
                  • 2178
                  #23
                  That'd be the plan anyway, that's useful information re the EGT and AFR guage, zeitronix have a nice digital display that will display boost and IAT later if needed. There's also a vems setup on ebay uk at the moment I might place a bid on.
                  Hi Shane,
                  John
                  Interesting to know those figures for reference. Must ask Paul what sort of runway is needed for road mapping.
                  Shane
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    #24
                    dont worry so much about the RS2 specs
                    take all your engine working PERFECT and then give him full boost
                    knock sensors should be new,the same as the ignition parts
                    good luck friend
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      #25
                      ah¡¡ and buy a wideband with gauge YES
                      i am using since 2 years ago a wideband from Innovatec motorsport...and all it is perfect¡
                      i am seeing 11.3AFR with 2.1 boost in 5th gear
                      • prj
                        • Mar 2010
                        • 6308
                        AEM wideband sucks.
                        Serial port, weird cable, no RPM/EGT/MAP input.
                        It's just a fancy gadget, which is totally useless for tuning.
                        I am using this:
                        • s2_wot
                          • Aug 2006
                          • 2178
                          #27
                          Will do Rocco, great advice
                          Originally posted by prj;532876
                          I am using this:
                          [url
                          http://14point7.com/SLC-DIY.php[/url]
                          Will check that out too, I would prefer one display to show boost, EGT, AFR and maybe IAT or something at the same time rather than the inside of the car looking like it parked in the pimp my ride / jap scrap / starship enterprise garage for a few days.
                          Thanks for the help folks
                          Shane
                          • prj
                            • Mar 2010
                            • 6308
                            Well, it only shows boost up to 1.5 bar (and that is if you install the MAP sensor).
                            I did it differently. The display is used for AFR/EGT, and for logging boost I just spliced the wire going into the trip computer (blue-yellow) at the back of the instrument cluster and stuck it into one of it's analog inputs.
                            That way I don't see boost on a gauge, but I can log it or see it in real time on my notebook.
                            For looking at boost, it might be a good idea to get a separate gauge. This can be done discretely though.
                            I will take a picture of my setup.
                            • prj
                              • Mar 2010
                              • 6308
                              Btw Shane,
                              If you don't fancy putting stuff together, the VEMS Round is also a very good idea.
                              It's 2x the price though and has less features.
                              Whatever you do, don't get the AEM if you are planning on using it for tuning.
                              • Jonnybravo
                                • Aug 2008
                                • 2051
                                Btw Shane,
                                People seem to get on perfectly well using them over here.
