knock, knock who's going to tune my s2 for me?
My understanding of the wideband sensor from a thread on here is that they are susceptible to damage by heat and therefore the bung should be further down in the downpipe, before the cats. Also they have a specific orientation to prevent moisture damage from condensation when the engine is switched off.
That leads me to believe that the narrowband should be in the stock location (m18 thread), the EGT somewhere in the same region (1/8" NPT thread) and the wideband down further down (m18 thread). I'll check those thread sizes later and repost if I'm wrong.
What I'm looking for (it seems) is a datalogger and display that will record and live report these other pieces of information. This will allow me to produce graphs and with the help of others, be they paid tuners or experienced others, I'll be able to fine tune the motronic based on what the engine in producing out the exhaust. CSI style. The display will be useful so I can see the EGT and if it's too hot back off, likewise if the AFR is outside what it should be I can back off too.
My simple mind tells me that the zeitronix ZT-2 with LCD display clearly shows 4 concurrent readings. I don't have a boost gauge yet anyway so AFR, Boost, EGT and fuel pressure would be my choice and datalog the IAT then just for giggles. I don't have to buy all the toys day 1 but rather when I have money for add ons. Anybody here using this equipment?
More research needed. But getting the bungs into the downpipe is in many ways the 1st step. More news on that later.
The other thing is that if I just go for a mildly tuned RS2 setup I won't need any of this stuff, so put in context I'll take the 1st part of Rocco's advise now and worry about the second part later.
All good input, probably should have said I was staying motronic at the outset.ShaneComment
I and many others have been using the wideband in the location of the narrowband sensor and have not had any issues.Comment
