where maps s2's in west yorkshire??
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    #31
    Originally posted by 4WheelDrifter
    Do we have any evidence that Automark can custom map Motronic M2.3.2 now? I am yet to see any.
    MBC or using an N75?
    SS
    • prj
      • Mar 2010
      • 6308
      Originally posted by DJones
      Yes there is one sat in my garage..
      Your car does not use the N75 valve though, does it?
      Originally posted by terrybullwon
      Steves car with some massive KKK and about 700hp
      On Motronic 2.3.2? Motronic 2.3.2 can't physically idle properly with injectors that are enough for 700hp. It is outside it's hardware specs.
      • DJones
        • Jun 2005
        • 2020
        He initially did mine with an N75 but i had no end of problems with the high boost i am using, i then went to MBC and now eboost2.
        • prj
          • Mar 2010
          • 6308
          How much boost are you running?
          • DJones
            • Jun 2005
            • 2020
            Originally posted by prj
            Your car does not use the N75 valve though, does it?.
            Not what he asked.
            • terrybullwon
              • Mar 2006
              • 8782
              Well yes it Idles.
              Chef
              • DJones
                • Jun 2005
                • 2020
                2.2 with water/meth 1.7 without.
                • prj
                  • Mar 2010
                  • 6308
                  Well yes it Idles.
                  Which injectors? What AFR at idle?
                  I didn't have any issues running 2.3 bar boost on N75... on multiple cars.
                  It's just a magnetic solenoid valve. You can use a turbosmart solenoid if you like, does not matter.
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    Which injectors?
                    Dunno ones that put fuel into the engine, i really dont have a clue
                    Chef
                    • prj
                      • Mar 2010
                      • 6308
                      Well, I am sorry if I am a little bit skeptical about you throwing up a number, then stating it can idle properly (and I don't mean flooding the engine with O2 trim codes) at that power level, when the hardware and software of the system is not really designed for it.
                      • DJones
                        • Jun 2005
                        • 2020
                        Well done you, this thread is not about your abilities. I dont deny they are good just dont want to keep hearing about them.
                        • prj
                          • Mar 2010
                          • 6308
                          It's not about my abilities. I am sure Mihnea and a lot of other tuners in Germany can map a car to run whatever boost on a N75 valve (or any other magnetically actuated boost solenoid) as well.
                          It is not that special, there are just certain nuances on higher power cars.
                          What is special is the statement from James that a car can have 700hp on this old Motronic and idle properly. I'd really like to see that.
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            Skip to 1.22
                            Chef
                            • prj
                              • Mar 2010
                              • 6308
                              That does not answer anything.
                              1. What injectors did it use?
                              2. What AFR did it run at idle?
                              3. Who says it has 700hp?
                              • terrybullwon
                                • Mar 2006
                                • 8782
                                Yes your right sorry i just made the whole thing up for no reason
                                Chef
