Launch control for Motronic
  • Thuppu
    replied
    Thats fully understandable.
  • prj
    replied
    Well my UrS is still in bits.
    I guess when you fly around Europe and tune others cars you don't have too much time for your own.
    I have not really pursued this much further, because no one really needs ignition based antilag that much.
    The only thing that I made is no-lift-shift with ignition cut, but it needs a button under the clutch.
    Even with a GT35R and the current Launch control you get about 0.5 bar and it does not bog down and spools up instantly. And then you can proceed with the no-lift-shift.
    So I think I got this covered pretty good as-is.
    It is really a question of sitting down and writing some code - I know exactly how to do it, and I have tested a concept that worked. I just do not have much time :/
  • djh
    replied
    Originally posted by prj
    I am mainly doing it "because I can"
    Btw, I am working on a properly configurable anti-lag system...
    Made 1.5 bar when stationary then I let off the throttle
    Originally posted by Thuppu
    Dmitri, how is the UrS? Any progress with the antilag?
    Any progress with this?
  • Thuppu
    replied
    When I get my UrS6 together again, then...
  • prj
    replied
  • djh
    replied
    Are you still looking into anti lag?
  • Rocco
    replied
    crazy nutter
  • Simons
    replied
    Hack this blue/white VSS wire into pin 50 on your AAN ecu and you are there - use vagcom to look at the group that reports speed in kph to verify that its working - then you are ready to launch !!!!
    Ok, I will use vagcom to verify VSS
    now I can't make any test because I needed remove the turbo...
    when I have VSS into pin50, and check with vagcom, I will fit launch's eprom and the party will begin
    Paul, I kinda did that on Simon's car when in Spain and it didn't seem to work...
    Maybe I did something wrong, but it still showed 0km/h.
    Hi mate! I forget to check if the signal was good or not, the wire was good attach to Bl/W... when I can check it, I will do it
    I need launch!!I tasted it, and now, I need it!!
  • prj
    replied
    replied
    simons - If you want to do launch control a different way then go ahead, but I am telling you that 3B VSS signal is what you need here. It is indeed pin 50 and you will get it as a blue/white wire that comes to one of the radio connectors. Dont confuse yourself any further by looking at it with a voltmeter - this is an AC signal that comes from the gearbox, via the speedo module.
  • Simons
    replied
    If you guys have gone to AAN ECU and coilpacks then of course all you need is to add VSS wire to the ECU plug. You know where to look up which pin...
    Or I can spell it out for you tomorrow - along with where to find VSS wire on a Coupe that left the factory with 3B engine !!!!!!!
    Yes...I don't remember...I think into pin 50...do you know the wire colour??
    But I think that the 3B VSS signal, isn't valid to do launch control...we need a frecuency, when I test the blue-white or white-blue to fit the cruise control, the signal was voltaje....I don't know how is the climate or the radio signals...
    Thanks!
    replied
  • Simons
    replied
    Originally posted by Rocco
    are you saying that WE CANT USE LC on our cars??
    We need to wait
    But we have AAN ecu...we have something...we need the signal
    The issue is threefold :
    1 - VSS signal needs added to 'spare' input pin on the 3B ECU connector... there are maybe a few possibilities for that
    2 - a hardware hack on the 3B ECU would need to translate the VSS signal into something the microcontroller inside ECU can do something with
    3 - custom software needs written for 3B micro that will understand the VSS signal... at least enough to ascertain the car is moving or not
    I guarantee that its easier to convert a 3B motor with coilpacks, loom adjustments, ECU swap for DI (direct ignition) operation than do all of the above.
    AAN, ABY and ADU ecus have hardware and software support for VSS
    3B ecu does not
    with 3B ecu is more difficul but not impossible
    Rocco and me have multicoils, and we are happy with the change...next step, remove dizzy and put hall like ABY,AAN,ADU
    replied
    3B ecu does not
    replied
