Again, just saying that you are smarter than everyone else is not something that will add any positive effect of what people will believe of you. Let your results speak for themselves. Otherwise you will end up being a king in a one man's kingdom.
as i mentioned already, personally i am not dissingin any way, any of the work that you have done so far. What i do want to see is results, and hopefully an easier way of fiddling with motronic( which probably never happen). Its a good thing that where motronic lacked proper management is now able to be tuned and aftermarket ECUs are not as much needed. Each have their own +/- and that is where the focus should be and among the many posts i think it is sort of clear of what those are!
