There is no book that will tell you exactly what to do.
All engines are similar to some extent - read the books, understand the theory, understand why you are doing something and then give the engine what it wants.
As for switching between LPG and Gasoline, yes you can easily do this on 3B ecu, requires a little knowledge of electronics, but it's pretty much using different chips and soldering a couple of wires. Very easy.
Ostrich allows you to real-time emulate your chips on your ECU and you can easily tune your car for LPG with it. But of course the problem with Motronic is to find all the maps needed...
If you do not intend to do it on a broader scale, it is much, much easier to buy VEMS and focus on tuning your car, than try to make sense of Motronic.
so true!
