Emulator Ostrich
  • karel5000
    • Jul 2011
    • 9
    Emulator Ostrich
    Hi,
    I have some questions about the Eprom emulator Ostrich 2.
    I have audi 200 20V 3B. One of the Eproms is 27C64. Is it possible to emulate this chip with the Ostrich 2 emulator? Eventually do you know something what supports this chip?
    If I use an emulator for the emulation of Eproms, do I also need a file with the names and addresses of tables? (For example for the software TunerPro?) Or using emulator I do not need such a file? The emulator finds it for me automatically? (Addresses and names of tables, units of axis...)
    Thanks very much for your help,
    Karel5000
  • blackS2
    • Apr 2010
    • 455
    You need two files - an you have to figure out the whole s**t on your own before you get any benefit from it... hours and hours and weeks and months of work....
    [__]=oooo=[__]
    • prj
      • Mar 2010
      • 6308
      Originally posted by karel5000
      Hi,
      Yes, it will support it. 27C64 has similar pinout to 27C256 and 27C512, just fewer address lines.
      Yeah you need a file, and you need to understand how the tables work between each other.
      No such files are publically distributed though.
      Look at this thread for some ideas:
      If you only want to tune your own car, I would not bother and go to someone who knows how to map this ECU.
      • karel5000
        • Jul 2011
        • 9
        Thanx very much for the ideas,
        Karel5000
