i need the above firmware if any users have it stored...it is not available now for download..without this my job is hell
vems 1.1.63 wanted
i wasnt aware of this regarding the coils and injectors from 1.1.83, so i did take the plugs off, installed the firmware, and put the plugs back on. Simple and doesnt take long.
you need to make sure you use a timing gun to set the timing again from 1.1.63 to 1.1.95
and i would suggest 1.1.95 as an upgrade.Comment
as i mentioned, use what you have, photograph every setting on your masic settings menu and all that values are not existent when you disconnect the ecu from the laptop. Then use the latest vemstune, reconnect and start the procedure of the upgradeComment
Not 100% sure, but I think you have to upgrade to something like 1.1.74 then to the new ones I went 1.1.74 to 1.1.88 to .1.1.95RS 2 580HPComment
