isv part no..?
  • cooperquattro
    • Jan 2011
    • 815
    isv part no..?
    has someone got a part no.for the isv to use with vems on aby,i am assuming i just need the standard one?
    is this the same stepper as on the bmw e36??0 280 140 529
  • cooperquattro
    • Jan 2011
    • 815
    anyone??
    surely someone has the bosch p.number for the isv valve??
      N71 Idle Speed Stabilization Valve (ISV or ISS Valve) Info
      Originally posted by cooperquattro
      anyone??
      Here is info about the Audi 20V turbo Motronic-controlled ISV valve (click on the "N71 ISV" label on the upper left of this diagram):
      • cooperquattro
        • Jan 2011
        • 815
        yes thanks thats the one n71
        • cooperquattro
          • Jan 2011
          • 815
          anyone have the p/n for the n71???
          or link to good cheap new one??
          very good used one???
          • martinws
            • Oct 2008
            • 917
            I dont have the part number to hand but iv got one for an ABY that was working fine on my car yesterday when i took it off? Its sitting in a box at my unit. PM me if that helps.
              If you followed the link URS4 boy gave you and then click on the hyperlink you get this page, scroll down.. http://forums.quattroworld.com/s4s6/msgs/21853.phtml
              • cooperquattro
                • Jan 2011
                • 815
                thanks i had totaly missed that part...
                can the isv vent to air instead of looping through the throttle body???
                i dont run a maf so unmetered air is ok
                  can the isv vent to air instead of looping through the throttle body??? i dont run a maf so unmetered air is ok
                  Only if you like the idea of unfiltered air being draw into your engine.
                  • cooperquattro
                    • Jan 2011
                    • 815
                    so possible then??with a crankcase style breather(filter) on the open end
                      Possible but I really don't understand WHY you would go away from a tried and true closed loop system.
