rs4 coil loom
  • cooperquattro
    • Jan 2011
    • 815
    rs4 coil loom
    is anyone making these yet or do i have to buy the plugs and do a diy??
    do the coils fit aby rocker cover,ditching the top part(cover)
  • prj
    • Mar 2010
    • 6308
    I could get you one made up, if you like.
    It will take a couple weeks though, until you have it.
    • jsws3
      • Apr 2012
      • 1174
      How much do you think it would cost with coil packs ?
        Originally posted by cooperquattro
        is anyone making these yet or do i have to buy the plugs and do a diy?? do the coils fit aby rocker cover,ditching the top part(cover)
        Looms have been available commercially since April 2006 following my DIY instructions posted in Oct. 2005. 034, Apikol and EFI Express all have looms that work with the 4 pin, internal POS, coil packs used on the 1.8ts, 2.0TFSI, 4.2L V8, RS4, etc.
        A complete kit, including 5 coil packs from Apikol is around US$360
        The one from EFI Express (Marc S. is an advertiser here) is around US$350 http://www.efiexpress.com/catalog/pr...products_id=66
        • Donnie
          • May 2010
          • 112
          I started a thread on here and got all the info on suppliers and wiring etc from thuppu and urs4boy and co.
          Its a medium sized pain - not a total ballache but not fun either.
          Also the coils fit nice in the aby cover recess
          • prj
            • Mar 2010
            • 6308
            I think coils are best sourced locally in case of any warranty problems.
            I can do between 150 and 175 GBP for a loom. It depends on application - all are custom made and for example the ABY one is slightly different than AAN IIRC, not to mention we do one for 3B -> ABY conversions).
            Advantage is no customs, because it's made in EU, and we use the most expensive wires, and tape, plus all the right grommets.
            All the materials are specified for use in the engine bay.
