Vems lost signal
  • roger shaw
    • Sep 2008
    • 129
    Vems lost signal
    Hi,all
    Got the engine running but only on 4 cylinders
    1-2-3-5
    In vems ignition outputs
    0=stepper output d (1a)push/pull 12/0v ec18 pin11=no1
    1=stepper output b (1a)push/pull 12/0v ec18 pin10=no3
    2=ignition output 4 (7a) grounding ec36 pin11=no5
    3=stepper output c (1a)push/pull 12/0v ec18 pin5=no4
    4=stepper output a (1a)push/pull 12/0v ec18 pin4=no2
    no=firing order
    the cyc that is not got a spark is 2=ignition output 4 (7a) grounding ec36 pin11=cyc4=no5
    the engine is an aby
    vems was running a 3b and has had an aby engine harness fitted
    the pin swap to the crank sensors has been carried out
    it has coil on plugs fitted and the wiring is correct(tested end to end from ecu)
    when testing spark in ignition outputs visual stepper D is firing both no1 and no5
    disconnect no1 and there is no spark at no5
    disconnect 1-2-4-3 and test no5 and no spark
    2=ignition output 4 (7a) grounding ec36 pin11=cyc4=no5,does this output require turning on somewhere in vems
    the cop harness was wired from diagramme off the forum
    hoping for help roger
  • roger shaw
    • Sep 2008
    • 129
    Hi all
    now running on 5
    ended up belling the ecu outputs
    changing from 3b to aby and then reverse engineering the engine harness to work with the vems ecu which was bought for a 3b has been a nightmare
    anyway alls well that ends well
    roger
