Yes i did pair the app. I can see the blue-tooth RS232 adapter in the app.
I will try some more settings when I'm at my car tomorrow.
Just to by sure, Is it possible to make a connection with the engine off?
VEMS Display Android application
VemsDisplay isnt avaliable for apple.
If you have an app for apple that communicates via the AIM-protocol and supports bluetooth, you could probably make it work.Leave a comment:
Did you pair your Android with the bluetooth device ? Settings -> Bluetooth -> Add bluetooth device (or something like that)
VemsDisplay doesnt display any devices that aint paired .Leave a comment:
Can some one look at my blue-tooth configuration if something is wrong?
I have a good blue-tooth connection between my VEMS and Tabblet.
But the Android VEMS app does not make a connection.
Is there something wrong in my RS232 to blue-tooth adapter?Attached FilesLeave a comment:
I used a cigarette lighter/USB transformer and took 5 Volt from it.Leave a comment:
how to supply power to rs232toBlurtooth and where to buy please tell me moreLeave a comment:
Hi,
don't know if you noticed but VEMS has made an Android application. I have put together a Bluetooth transmitter for it and connections for power and it seems to work pretty well. Much better/faster than the LCD display. It is almost realtime (a tad slower than on the PC).
take a look here:
Tags: None
