VEMS w 60-2
  • 90/90qs
    replied
    Looks like you were correct Prj. Cam is out of phase... I guess I need to rearrange my ignition triggers or something.
    Trying to work out my options.
  • a4kquattro
    replied
    I replied to your question over on quattroworld. Repost of the text here so it might help others:
    Vemstune makes the process pretty easy. just go under base setup->primary trigger settings.
    at the bottom of the page where it has a drop-down that says "defaults", select 5cyl_60-2. it will set a bunch of things on that page. burn the settings.
    Now go to your ignition outputs visual page and make sure all of that stuff makes sense.
    Next up is the really important part, which is zero-setting your ignition timing. where your flat teeth are can vary from setup to setup, so to dial it in go to tools->ignition lock and set it to some small value, I usually use 1 degree (you'll need a dial advance light set at 1 to make it line up). alternately you can edit your timing map so it cranks over at 0 degrees. entering "0" into the ignition lock disables the feature. Grumble.
    so with timing locked at zero, go to the base setup->primary trigger settings visual page. flash your #1 wire against a known TDC cyl #1 reference mark (flywheel, balancer, whatever). if its off, adjust your "TDC After the trigger" setting until it does line up. If you have to move your value under 60, or you run out of adjustment on the top end of the field, you'll need to shuffle your ignition output order so that it can be within that range.
    dont forget, you need a cam sync for this to work. no wasted spark 5 cylinder possible on vems due to a firmware limitation (only 8 ignition phase entries. you need 10 minimum to do waste spark on a 5 cyl. I've asked for it, probably a coming soon feature).
    before any of this matters, you need triggers first. if you dont get any spark check your triggerlog to make sure the wheel is being read properly by the ecu.
  • 90/90qs
    replied
    I don't have the VW trigger wheel, although I've read that thread and it looks like a nice option. I bought the 034 full kit with all the goodies a couple years ago, so that's where the 60-2 came from. - I still have it but my switching is about a number of things that appealed to me, with VEMS and frustrated me about 034.
    034 software, horrible application UI. Perhaps the worst I've seen when it comes to usability. Kinda like someone tried to reinvent the wheel, and it didn't work out
    I've also spent tons of money with those guys, and been frustrated every single time including attempts with customer service; I'm a nice patient guy, and I kept thinking the next time will go better. Never happened though unfortunately.
    I bought the VEMS because I have a second project and thought I'd trade up and compare. The 034 is going into #2.
    So far VEMS is much nicer when it comes to configuration and usability, I do have a long way to go though and I've been trying to get to simply fire up even once for what must be 6 months... :-\
  • cooperquattro
    replied
    Is 60.2 the vw polo crankseal???someone on here used it
    replied
    Ask on the vemsforum and review http://www.vemssupport.com/forum/ind...ic,1996.0.html
    Gintk knows his stuff
  • prj
    replied
    I have not set up VEMS with 60-2 before, but I had a similar issue with ViPeC.
    And it turns out that the phase was 360 degrees out.
    So the cam sensor zero point had to have 360 degrees added to it, and after that it fired right up.
    No idea if this helps, but thought I'd throw this out here.
  • GazzaG60
    replied
    i know it can be done with 60-2. i rememebr chatting to teppo a few years ago about this.
    can i ask why the 034efi wasn't any good?
  • A80Avant
    replied
    I was under the impression that the 60.2 would realt need a specific number for the spark angle to be calibrated and nothing else significant. Ill pm you to see if there is something else wrong.
    The vems community forums is another place yoi could ask, although it seems fairly quiet lately
    sent with WSGS3
  • 90/90qs
    replied
    I've posted on quattroworld, and Marc replied with a few suggestions, but I was trying to avoid using his time too much before I have some reasonable questions.
    It seems the majority of folks he works with are using the stock harness, coils and triggering off the flywheel.
    I've gotten a few config files from those folks, but unfortunately they don't bear much resemblance to my setup.
    I'll follow up again and see if he might be able to specifically identify someone with a 60-2.
    -If you're willing to take look I think the issue would likely be easy to spot....
  • A80Avant
    replied
    Have you spoken to marc swansson at efiexpress?
    He would be able to help you out. I'm sorry I haven't been using 60-2 and ppssinly couldn't help.
    I can pm you my email anyway to have a look.
    sent with WSGS3
  • 90/90qs
    started a topic VEMS w 60-2
    VEMS w 60-2
    Hey folks I'm trying to get my engine started with a VEMS V3, and I'm looking for some help from those who may have a similar configuration.
    I picked up the ECU and V3 harness with relays and all, with no pre-configuration from vems.hu.
    This system is being retrofitted to my AAN, previously running a full 034efi IIc system; so I'm using the HO Coils, 60-2 trigger wheel, and Siemens Deka injectors.
    (GTX-3071R)
    All of my wiring is installed
    injectors click and coils spark when tested
    Primary (VR) and secondary (CamHALL) Triggers are good
    timing tests show a good TDC reference during cranking
    Batt voltage is ok
    fuel pressure is good
    but something is mis-configured in my software. Never once does a spark ignite fuel while I'm cranking, I only smell the flooding after cranking a few times for 10 - 15 second intervals... I am relatively new to doing diagnostics on the VEMS software, and somewhat new to understanding what I'm doing when it comes to proper configuration. -I'm learning as I go, reading a lot of forums and published information etc. but the granular detail is beyond me at this point.
    What I'm hoping is that someone with a VEMS system, using a 60-2 is around here and would send me a config file. I could look over it to answer some of my questions, and then come back with more informed Q's.
    - I think I've truly exhausted my own investigative options, and now I just need a little help to get me going again! If anyone can, I would be indebted!
