Trigger Problem
  • Thuppu
    • 4115
    Yea, but many have problems with Vems and stock triggers. The problem usually appears on very high rpm's. The VW Lupo trigger is defenitely a good upgrade.
    • QuattroFever
      • May 2006
      • 1360
      Originally posted by Biturbo
      just not too much then you will damage sensors
      BTDT
      Volcano ABY coupe
      Ant
      • QuattroFever
        • May 2006
        • 1360
        Lupo trigger mod is 60-2 wheel behind flywheel?
        Volcano ABY coupe
        Ant
        • murat
          • Oct 2005
          • 167
          • Country: Turkey
          Here is a log file from 29 october
          I dont want to hassle with 60-2, I want to continue with original. Maybe find a way to improve the signal quality
          Thanks for help
          Murat
          • roger shaw
            • Sep 2008
            • 129
            Hi
            running vems on an ABY engine,modified
            when I was trying to get it to run I also had a lot of trigger errors,7A flywheel
            this may help or not,fitted a good earth strap from the cam cover to the chassis
            trigger errors went away but if I log the triggers it is still missing the triggers
            the pin on the flywheel is 4mm(7A flywheel)
            the pin on the ABY duel mass flywheel is 6mm(cast into the flywheel)
            does not sound alot but is a massive difference in the flesh
            this was not a perminant solution as I am going to make a piece of tube to fit the pin and weld it on
            but the engine not runs ok with no missfires
            hope this helps
            Roger
            • kamuto
              • Oct 2009
              • 83
              • Country: Lithuania
              #21
              there isn't any trigger error in your log
              • roger shaw
                • Sep 2008
                • 129
                when looking at the log file
                on tickover all is ok
                when increasing the revs there is gaps in the log and missfires
                this was before the extra earth strap was fitted
                also when trying to get rid of the trigger erors I used 3 x different sets of vr sensors and they were all the same
                I did try running with the sensor touching the flywheel,could hear it rubbing,that made no difference
                Roger
                • murat
                  • Oct 2005
                  • 167
                  • Country: Turkey
                  #23
                  But why do have this rev counter hesitation then?
                  I always thought it was trigger error
                  Murat
                  • Takumi
                    • Oct 2009
                    • 120
                    • Home: Lithuania Current: United States
                    #24
                    got this 'issue' in the same rev range as yours...maybe it's just related with tacho/VEMS output signal noise etc...
                    BLOG: http://quattro10vt.wordpress.com/
                    • V6quattro
                      • Sep 2008
                      • 949
                      Thanks for help
                      Hassle with a 60-2? 60-2 works perfect for my. Just fit one and never look back!
                      1360kg/600Whp Avant 0-200km/h 9sec
                      • Billman
                        • 4129
                        #26
                        I can't open this log....it crashes everytime I try to open it (maybe bad CRC while downloading or something) but can it be that your VEMStune has a low baudrate setting and it logs too slow up there?
                        Go Holset or Go RS4
                        • murat
                          • Oct 2005
                          • 167
                          • Country: Turkey
                          #27
                          I log with 19200 i think
                          My vemstune is always uptodate using manual update. If you are not updating manually, that can be the problem.
                          Murat
                          • Billman
                            • 4129
                            #28
                            no, mine is also up to date and I had trigger issues before because of the 7A flywheel pin. I try again to download your log on another PC.
                            Edit: I had to update manually!
                            Go Holset or Go RS4
                            • Billman
                              • 4129
                              #29
                              There is a communication error man...the log jumps i.e. 7:08 to 7:10 in a blink of an eye.....
                              Go Holset or Go RS4
                              • Erikk
                                • Jul 2008
                                • 103
                                Probably noise from ignition system. Bad ignitioncoil grounding? Try changing plugs to the ones with buildt in resistors.
                                How are the condition of the rubberseal/whatever thats between the coil and plug ?
                                Audi S2 Avant - 600whp
