Audi S2 with more boost problems
  • rs2spinelli
    • Jan 2013
    • 15
    • Country: Brazil
    Originally posted by prj
    1. Difference between ABY and RS2 chipset is not only MAP sensor.
    2. You don't even know if it's cutting spark or fuel, and you want to tune this ECU?
    its cutting spark! not fuel!
    • prj
      • Mar 2010
      • 6308
      This ECU never cuts spark.
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Bang!
        SS
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          Originally posted by 4WheelDrifter
          Bang!
          • Guslotti
            • Mar 2011
            • 182
            • Home: Italy Current: Brazil
            #20
            Yes, you are right PRJ! In the past I had cut-off problem (Boost pressure exceeded) and using a ROSS-TECH graphic I could see that the time injection went to “0” zero. The problem was due a poor contact in Mass Air Flow sensor.
            • rs2spinelli
              • Jan 2013
              • 15
              • Country: Brazil
              #21
              this peace of Sh#$¨&#%$¨#$ ecu cut!!! and its not fuel i garantee you!
              FUELTECH FOR LIFE! thats the way! And cyo motronic!
              • prj
                • Mar 2010
                • 6308
                Then that means the issue is with ground on manifold, or a trigger.
                Or you damaged the ECU when working on it.
                The ECU software never ever cuts spark.
                Do what you want with the car, I am just here to set the record straight.
                • rs2spinelli
                  • Jan 2013
                  • 15
                  • Country: Brazil
                  #23
                  PS: i use ethanol.... not gasoline!!! gas is for weack audis! Ethanol fasters only!
                  • prj
                    • Mar 2010
                    • 6308
                    Go on, flame me for this, but it had to be said
                    • rs2spinelli
                      • Jan 2013
                      • 15
                      • Country: Brazil
                      #25
                      ok but he cuts anything!!!! lol!
                      • rs2spinelli
                        • Jan 2013
                        • 15
                        • Country: Brazil
                        #26
                        bout what? ethanol and gas??? lol ethanol 1000000000 better!
                        • prj
                          • Mar 2010
                          • 6308
                          If spark and fuel are cut both, then ECU software has nothing to do with it.
                          But if ECU goes to safe mode, then I am sure spark is not cut
                          As I said, do what you want with the car - you will never figure out how to tune Motronic properly anyway, so might as well fit something else.
                          • rs2spinelli
                            • Jan 2013
                            • 15
                            • Country: Brazil
                            #28
                            PRJ u got some binaries to send me just to try?
                            • prj
                              • Mar 2010
                              • 6308
                              And I guess you want them for free?
                              And then you probably want to also copy paste their contents and see what is changed...
                              I don't really feel like it, sorry.
                              • rs2spinelli
                                • Jan 2013
                                • 15
                                • Country: Brazil
                                #30
                                ok... if i send my binaries to you... you can just take a look and tell me whats going rong?
