DIY Mapping, I5 experience
  • Audiboys4
    • 56
    • Country: Norway
    #61
    Last time I went on the dyno, the tuner used this :
    I liked it very much, expensive though
    Been searching around, but this seems to be the only one able to logg the data with its own software, that I can find anyways
    Audi Rs2
    Audi A3 Sportback
    Ducati 1098R
    • prj
      • Mar 2010
      • 6308
      It's just a normal two channel amp with filter.
      For the software - use your ECU!
      Your Autronic should support knock control and logging of knock sensors.
      • Audiboys4
        • 56
        • Country: Norway
        #63
        Yes it should, but as far as I have gathered, thats not happened yet, only for subaru and EVO PNP solutions....
        this is what they recommend until they get their solution in order (which has taken ages) :
        Audi Rs2
        Audi A3 Sportback
        Ducati 1098R
        • prj
          • Mar 2010
          • 6308
          Heh...
          Should have went with ViPeC then I guess.
          But really this thread is DIY mapping.
          DIY mapping especially if it's your first time learning, you buy VEMS because community support is by far the best, and end of story.
          For someone who is starting this is the single most important thing, everything else is secondary.
          • GazzaG60
            • 4133
            think prj is correct.
            when I did my vems other than marcel and teppo I had nowhere to turn. teppo was amazing and really helped where I was stuck. he is afterall the auditrigger master.
            now there are a crap load of vems users and most will give others a hand. kind of like returning early favours.
