vems iat issue
  • cooperquattro
    • Jan 2011
    • 815
    vems iat issue
    My iat seems to be stuck at -9`c,I am using 1.8t ntc type sensor with 2254 patch,if I try the old ptc sensor I get 17`c,but using either the iat or mat reading doesn't move,removing the sensor I get _40`c(which is correct)
  • A80Avant
    • 10873
    • Country: Greece
    Try another sensor. If its ok then its just the sensor. They are very cheap. I haven't heard of the module in the ecu to break down
    • cooperquattro
      • Jan 2011
      • 815
      Cheers vas will try another sensor,I allready tryed 2 aby sensors but they didn't work,will try a new1.8 one
        You can't switch sensors between ntc and ptc with VEMS on the fly, only 1 sensor type can be active at a given point in time, there's a resistor on the motherboard that governs this so the ABY ones wont work. You need to try a new sensor like Vas says and check that your using the patch file values in the ecu settings
        • cooperquattro
          • Jan 2011
          • 815
          Ok cool,I am sure the ecu is set up for ntc(as in resistor on the board)that's probably why the ptc is not working,I will try a new one,I used 2254 patch
          Is there a prefered make to use??ie Bosch etc
          • A80Avant
            • 10873
            • Country: Greece
            Yes indeed. I thought you knew that.
              You should be using 2252/256 for a Bosch 1.8T NTC
              • cooperquattro
                • Jan 2011
                • 815
                Yes sorry.thats the patch,just couldn't remember the exact no.
                Do you guys know the Bosch part no. Thanks Martyn
