High boost misfire VEMS and LS coils
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    FYI,i have D514a coils for many years.they're almost the first batch of running
    LS2 coils conversion.Previously,i had D585 coils from EFIexpress and finally sold
    to a guy locally.both sets is still running flawlessly.one thing i noticed now we got
    a chinese knock off coils available in the market and they're harder to be justified
    if they're genuine or Reps.some of them has a reliable quality but some of them
    is trash.
    one of a few I5 from Asia.
    • V6quattro
      • Sep 2008
      • 949
      is trash.
      Do you think it is best to order a genuine set at the dealer?
      • A80Avant
        • 10873
        • Country: Greece
        I got everything from Marc and they have been fine.
        • V6quattro
          • Sep 2008
          • 949
          I also had my set from marc @efiexpress. Was perfect for 5000km but with my new loom i have misfire's. At what dwell and charge time do you have your coils?
          • popdemonic
            • Dec 2007
            • 1304
            • Country: Thailand
            #20
            if you purchased them from Marc.don't worry about them.he always stand behind his goods.
            • A80Avant
              • 10873
              • Country: Greece
              #21
              I'll double check and let you know tonight. I do have the dwell at 20 I think. I get a validation yellow alert but ignore it as per Marc's advice.
              • V6quattro
                • Sep 2008
                • 949
                as in 20ms dwell time? Is that not really high?
                I also have a yellow alert as you can see.
                • jade
                  • Jan 2005
                  • 1811
                  • Home: New Zealand Current: Spain
                  #23
                  Just checked mine 4.99 ms & 4
                  RS 2 580HP
                  • V6quattro
                    • Sep 2008
                    • 949
                    Thanks jade
                    Maybe i sould just run my car at higher dwell settings.
                    Only thing about that i don't like is the fact that my car was running flawlessly on the old settings and now i have to double the dwell time to get no misfire's.
                    How could that happen? Only thing i can think about is that the coil with the weak spark is defect and can now only perform right at high dwell settings. But can thees coils go bad when not used
                    • A80Avant
                      • 10873
                      • Country: Greece
                      #25
                      Thanks jade
                      Mine are 2.5ms and 20
                      As you say before changing settings just change sequentially the coil cable and then the coil if it still misfires. I had a loose spark plug which ate the coil cable. Thankfully it doesn't misfire anymore and I didn't have to change the coil itself
                      • jade
                        • Jan 2005
                        • 1811
                        #26
                        Quite a different in settings I had a misfire so I increased dwell time and no misfire
                        RS 2 580HP
                        • V6quattro
                          • Sep 2008
                          • 949
                          Yes i already change the coil to rule out all the wiring. Only i did not change the coil cable so i will try that tomorrow. The coilwires ware fine last year but you never know
                          For what i understand about it the coil charge time map scale settings is also impotent. If you set it high it will up the dwell when on boost right?
                          • V6quattro
                            • Sep 2008
                            • 949
                            But just to by sure i ordered 5 AEM coils. Can't wait to try them.
                            http://www.aemelectronics.com/high-o...mart-coil-1240
                            • Erikk
                              • Jul 2008
                              • 103
                              I use those coils, but the "dumb" version driven by Vems IGBT. Really nice
                              Audi S2 Avant - 600whp
                              • A80Avant
                                • 10873
                                • Country: Greece
                                #30
                                I got the full set from marc. So I don't know what make they are. That how much trust I have put on him
