VEMS problems
  • vwnut8392
    • Jul 2012
    • 418
    VEMS problems
    Ive been trying for several weeks now to get VEMS setup and running on my car with little luck. im currently attempting to run 60-2 crank with a GM LSx magnetic hall sensor and the factory AAN hall cam. i have trigger events in my trigger log from both sensors but no fuel or spark. i keep getting too many secondary triggers in the log as well. im not 100% sure my primary trigger wheel or the settings are correct either.
    here's some pictures of my trigger wheel setup.
    This is a VR6 60-2 trigger wheel mounted to the front of the AAN damper pulley. notice the labels i made. im not sure if this is right.
    These are my current primary trigger settings.
    This is the air gap between the sensor and the wheel.
    does all of this look proper and why am i getting the too many secondary trigger error in the trigger log? can anyone help?
    "The really good drivers got the bugs on the side windows." Walter Röhrl
  • rst
    • May 2006
    • 102
    AAN damper pully has rubber inside so it will likely give you trigger errors on higger rpm in the furure if you get this started now.
    Why are you not using stock sensors in stock places?
    They work well up to 8500rpm.
    Audi UrS4 609hp/846Nm @ wheels
    10.911@210, 1km 268km/h, 1mile 295km/h
    FATS 2,30 sec
      Originally posted by rst
      AAN damper pully has rubber inside so it will likely give you trigger errors on higger rpm in the furure if you get this started now.Why are you not using stock sensors in stock places? They work well up to 8500rpm.
      From the sidelines, I think VWnut8392 likes to do things his way, even if it means reinventing the square wheel. Most normal people who go to VEMS on an AAN use the system developed by Marc S. at EFIExpress that does indeed reuse the OE T55 connector with its links to the OE sensors that the OE Motronic ECU used and adds a few more inputs to the VEMS box.
      http://www.efiexpress.com/catalog/pr...&products_id=1
      • vwnut8392
        • Jul 2012
        • 418
        im too poor to afford the PNP ECU so i got stuck with buying an econoseal version. im working with what i have and what i can afford honestly, thats how life has always been for me and always will be.
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          I would connect the original crankshaft sensor to your VEMS
          it is still on the engine?
          TWINCHARGED power,zero lag
          AEM W/M injection
          • a4kquattro
            • Feb 2005
            • 411
            post a trigger log.
            Marc Swanson
            Proprietor, EFI Express
            95.5 //S6 Avant
            90' Coupe Quattro V8 4.2L twin turbo
            93' //S4
            83' UrQ
            97' F250 7.3 diesel
            • vwnut8392
              • Jul 2012
              • 418
              Originally posted by a4kquattro
              post a trigger log.
              Here's a picture of my trigger log since this forum wont let me upload the actual file. i hope this works for you.
                Marc has an email address. You could try sending him the trigger file. Might work.
                OR you could export it as an Excel file. Pretty sure you can upload Excel files here (BTDT).
                • Val
                  • Apr 2008
                  • 630
                  • Country: Latvia
                  you can archive your log file in a zip.
                  5vtq gte
                  • vwnut8392
                    • Jul 2012
                    • 418
                    good thinking! my brain is fried right now......
                    VEMS log atttached.
                    • a4kquattro
                      • Feb 2005
                      • 411
                      all kinds of wrong. the reason its saying too many secondary triggers is because it isn't getting enough primary triggers.
                      If I'm reading this right, it looks like its only reading the missing tooth on your primary. try adjusting your sensor gap (probably closer).
                      when its correct, you'll be seeing 58 primary teeth, a gap, 58 more primary teeth, then a secondary trigger, then repeat.
                      Marc Swanson
                      95.5 //S6 Avant
                      93' //S4
                      83' UrQ
                      97' F250 7.3 diesel
                      • vwnut8392
                        • Jul 2012
                        • 418
                        Thanks Marc, I'll mess with the sensor location more and see what I get. I felt that trigger log was way off from what I got out of the jimstim on 60-2 setting.
                        • vwnut8392
                          • Jul 2012
                          • 418
                          thanks for the help guys. it turns out the GM crank sensor was wrong orientation, i flipped the sensor 90 degrees and it picks up the 60-2 trigger wheel perfectly now! on to the next hurdle.
                          • V6quattro
                            • Sep 2008
                            • 949
                            Nice work
                            1360kg/600Whp Avant 0-200km/h 9sec
                            • vwnut8392
                              • Jul 2012
                              • 418
                              well guys i got it running and it idles but i cant rev it over 2300 RPM. it comes up with a less primary trigger error. also my coolant temp and MAT values are completely wrong. i attached a trigger log so maybe you guys can help me with whats going on. also with the temperature values i tried what marc suggested the patch setting are in his web site but that seems to have no effect.
