Ive been trying for several weeks now to get VEMS setup and running on my car with little luck. im currently attempting to run 60-2 crank with a GM LSx magnetic hall sensor and the factory AAN hall cam. i have trigger events in my trigger log from both sensors but no fuel or spark. i keep getting too many secondary triggers in the log as well. im not 100% sure my primary trigger wheel or the settings are correct either.
here's some pictures of my trigger wheel setup.
This is a VR6 60-2 trigger wheel mounted to the front of the AAN damper pulley. notice the labels i made. im not sure if this is right.
These are my current primary trigger settings.
This is the air gap between the sensor and the wheel.
does all of this look proper and why am i getting the too many secondary trigger error in the trigger log? can anyone help?
0-200km/h 9sec
